cooling system bleeding?
Old Jun 24, 2004 | 06:53 PM
ScoobCivic's Avatar
Default cooling system bleeding?
anyone know how to bleed or burp the cooling system?......changed cap, radiator, thermostat, nothing worked, still overheating after 20 min of driving... maybe some air stuck in there?.........
Old Jun 24, 2004 | 07:01 PM
ScoobCivic's Avatar
Default Re: cooling system bleeding? (ScoobCivic)
bump
Old Jun 24, 2004 | 07:11 PM
crazy eyez killa
Guest
Posts: n/a
what year civic do you have, what motor?
What kind of thermostat did you use? Generic thermostats such as autozone or kragen are notorious for being defective.
Old Jun 24, 2004 | 07:17 PM
97ShLude's Avatar
What engine are you working on?
I know that some engines have a bolt on top of the thermostat housing that releases air and is used for bleeding and some are near where the upper rad. hose connects to the block (where it was on the lude). But I am pretty sure some don't have the aforementioned bolt.
Is your water pump good? Rad cap good? Rad hoses? Your fan switch might also be bad which would cause it to overheat if you are stopped alot. Just check everything associated with the system and don't get frustrated. Good luck!
Old Jun 24, 2004 | 07:23 PM
ScoobCivic's Avatar
its a 99 si b16 ya and i got it from autozone, it oem one
krysted9354
Feb 26, 2009 04:01 PM
briq4
Honda Civic (2001 - 2005)
10
Feb 5, 2007 10:43 PM
89_ZC_crx
Mar 12, 2006 08:35 AM
romeo619romeo
Jul 15, 2003 08:19 PM
TurboIntegra
Oct 26, 2002 03:54 PM
