cooling system bleeding?
anyone know how to bleed or burp the cooling system?......changed cap, radiator, thermostat, nothing worked, still overheating after 20 min of driving... maybe some air stuck in there?.........
Re: cooling system bleeding? (ScoobCivic)
What engine are you working on?
I know that some engines have a bolt on top of the thermostat housing that releases air and is used for bleeding and some are near where the upper rad. hose connects to the block (where it was on the lude). But I am pretty sure some don't have the aforementioned bolt.
Is your water pump good? Rad cap good? Rad hoses? Your fan switch might also be bad which would cause it to overheat if you are stopped alot. Just check everything associated with the system and don't get frustrated. Good luck!
