vented discs..stock calipers
Old Jun 24, 2004 | 06:22 PM
bm3r's Avatar
Default vented discs..stock calipers
i want to upgrade my front brakes to a set of vented/xdrilled rotors. is it possible with stock calipers? or should i not even replace the rotors because the stock brakes suck?
maybe i should save more money for a whole bbk and rear disc conversion
Old Jun 24, 2004 | 06:43 PM
SOHC4life 96's Avatar
Default Re: vented discs..stock calipers (bm3r)
get brembo blanks and performance pads, save you a lot of time and money replacing the pads. slotted and drilled just tear up the pads.
Old Jun 24, 2004 | 06:44 PM
CPCivic04's Avatar
Why dont you go 5 lug conversion? theres bigger brakes for you and you have rear brakes too
Old Jun 24, 2004 | 07:06 PM
97ShLude's Avatar
Default Re: (CPCivic04)
No No No.....
1) Buy Integra Brakes (Front and Rear)
2) Get Prelude front calipers and rotors and drill the rotors to fit 4 lug
3) Get Carbotech brake pads for the front
4) Bleed brakes and fill w/ quality brake fluid
Period, that is all you should do. Its an awesome set up that doesn't cost nearly as much as the 5-lug conversion perviously mentioned and you will get exactly if not better perfomance.
Old Jun 24, 2004 | 09:17 PM
bm3r's Avatar
Default Re: (97ShLude)
what if i just get the integra brakes all around? just stock discs and calipers? are those good enough? how many pistons are they? im not looking to spend a lot..lets say $3-400 in total. what can i do with that?
i dont autox a lot, only once in awhile. i just want a setup with more bite on the streets.
thanks guys
Old Jun 24, 2004 | 09:58 PM
Jon5240's Avatar
Default Re: (bm3r)
acrua tl calipers (dual pistons) bolt up to GSR brakes
Old Jun 25, 2004 | 12:51 AM
blackdelslo's Avatar
Default Re: (Jon5240)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">slotted and drilled just tear up the pads</TD></TR></TABLE>
lol your such a dumbass n00b. I bet youve never seen cross drilled rotors.
I dont know how many times i have to say this. If your not planning on braking hard at high speeds consistently than cross drilled and or slotted arent as much as a benefit. COOLER BRAKES ARE BETTER BRAKES PERIOD. Once your brembo blanks get really hot is when they stop performing as well while my cross drilled and slotted are still performing great.
Oh and professional race teams dont use them for looks. They actually have their purpose.
Old Jun 25, 2004 | 04:24 AM
96 SOHC VTEC's Avatar
I saw first just try getting better pads and brake fluid. If you aren't satisfied with the stopping power after that then look to getting bigger brakes.
Old Jun 25, 2004 | 04:35 AM
91civicDXdude's Avatar
everyone i know with crossdrilled/slotted rotors onthe front have warped them. get a good set of blanks on the front and maybe crossdrilled for the back.
and btw, 5 lug conversion is gay. nothing is cooler than not being able to find wheels that fit and paying an assload of money for some cosmetic ricer mod.JDM y0!
Old Jun 25, 2004 | 05:05 AM
john666's Avatar
crossdrilled / slotted rotors do give a bit more wear on your pads. i drive alot so for me i dont mind replacing them more often as long as i stop.
Modified by john666 at 3:06 AM 6/26/2004
Old Jun 25, 2004 | 01:42 PM
Default Re: vented discs..stock calipers (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC &raquo;</TD></TR><TR><TD CLASS="quote">
Oh and professional race teams dont use them for looks. They actually have their purpose.</TD></TR></TABLE>
i did know that it cools the brakes but still i dont think that he is going to be racing anytime soon. so therefore i sugguested he just get some performance pads and better rotors. i also know that bigger brakes(bbk) cause a lose in power. more rotating mass causing the engine to have to work harder to get that extra weight moving. so dont just assume i dont know a thing about brakes because i made the most logical suggestion for HIS application.
Old Jun 25, 2004 | 01:56 PM
Jon V's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">and btw, 5 lug conversion is gay. nothing is cooler than not being able to find wheels that fit and paying an assload of money for some cosmetic ricer mod.JDM y0!</TD></TR></TABLE>
don't be mad cause you can't afford it.
11.25" rotors doesn't seem like a ricer mod to me
ya it's not like the USDM ITR came with 5 lug wheels or anything.
You have to go to Japan to get those
Old Jun 25, 2004 | 02:10 PM
Eminent's Avatar
Go with the Brembo blanks and good pads.
shwepes
Suspension & Brakes
Jan 23, 2016 06:17 PM
Jim Dan
Honda Civic (2001 - 2005)
Apr 17, 2013 12:42 PM
smirff07
Honda Fit
Dec 1, 2007 11:48 AM
wizzards581
16
Sep 17, 2003 06:16 PM
Vinceg99
Nov 15, 2002 10:00 AM
