question for hondata users, with with the launch control option
i have an 88 crx dx, and as you all know it does not have a clutch switch. my question is how did you mount the switch, that comes with the hondata to be able to activate the launch control? how did you mount that switch? pictures would help! TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 »</TD></TR><TR><TD CLASS="quote">anyone, someone must have done it!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sobe_Death »</TD></TR><TR><TD CLASS="quote">your car doesnt have a clutch switch? mine does, you have to depress it to start it(91 lx)</TD></TR></TABLE>i did mention that on the first post, i need to know what did people with 88-89 crx/civic did since our cars don't have a clutch switch. i specifically need to know, what mods were done, in order to retrofit the clutch switch. i hope that clears it up a bit!
you know, if it really came down to it, i think you could probly either rob the switch from a honda that has one(there should be a mounting point for it) or grab a pedal assembly from one that has the switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster »</TD></TR><TR><TD CLASS="quote">Even when there is no switch, there is always ad adjusting bolt to be able to adjust the free play in the clutch.</TD></TR></TABLE>
that adjustment is on the clutch release arm, not on the clutch pedal!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sobe_Death »</TD></TR><TR><TD CLASS="quote">you know, if it really came down to it, i think you could probly either rob the switch from a honda that has one(there should be a mounting point for it) or grab a pedal assembly from one that has the switch.</TD></TR></TABLE>
i'll have to hit the junkyard, to check out how the 90-91 clutch pedal looks like. this might be one of the options available, if anyone else know of any other way to mount it let me know!
*Boostwerks*
Nov 18, 2004 09:42 AM
IN VTEC
Jul 6, 2004 12:35 AM
