H22a EK civic clutch replac. ques....enuf clearance to drop trans?
OK h22a swap guys.....quick ques.
Well I have milked this clutch as long as poss. its time to go.
I was wondering If I have to pull the motor to get the tranny off.....
or if I would have enough clearance with motor still in or by removing some mounts?
clearance is questionable!!
You should just be able to unbolt it and drop it. Thats what we did in our 92 civic(rest in piece) and there is less room on that. Just make sure it sits low enough to clear the frame and it will slide right out. That was one of our concerns when we first put it together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master »</TD></TR><TR><TD CLASS="quote">You should just be able to unbolt it and drop it. Thats what we did in our 92 civic(rest in piece) and there is less room on that. Just make sure it sits low enough to clear the frame and it will slide right out. That was one of our concerns when we first put it together.</TD></TR></TABLE>
Yeah right now that my only concern
Thats what I figured just makin sure, rather not guess.
thanks
thanks
