NEED HELP ASAP INSTALLING TACH IN EG!!!
Old Jun 24, 2004 | 04:41 PM
mario82686's Avatar
From: Between San Diego and the OC, SOCAL, United States
Default NEED HELP ASAP INSTALLING TACH IN EG!!!
I am installing an Autometer tach in my eg right now and cant seen to find where the green wire goes.
Old Jun 24, 2004 | 04:43 PM
mario82686's Avatar
I have a 93 Civic EX
Old Jun 24, 2004 | 04:47 PM
Vintech's Avatar
Default Re: NEED HELP ASAP INSTALLING TACH IN EG!!! (mario82686)
it goes to the distrubutor, there are two clips on the distrubutor, on the closer one there are two wires Yellow/Black and Blue, splice into the blue one i think, there is alot of tape and i have a bad memory, also use solder.
P.S. try searching first, autometer will have the anwser, or search honda-tech.
Now all you have to figure out is which wires to clip on the back of the tach!
Modified by Vintech at 7:58 PM 6/24/2004
Old Jun 24, 2004 | 04:48 PM
mario82686's Avatar
Where on the distrubitor which wire?
Old Jun 24, 2004 | 04:50 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
If I'm not mistaken it goes through the firewall into the negative terminal of the ignition coil. Otherwise it goes to the tach terminal if you have a MSD electric ignition. Correct me if I'm wrong.
Old Jun 24, 2004 | 04:53 PM
mario82686's Avatar
Default Re: NEED HELP ASAP INSTALLING TACH IN EG!!! (BrokeAssPinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">If I'm not mistaken it goes through the firewall into the negative terminal of the ignition coil. Otherwise it goes to the tach terminal if you have a MSD electric ignition. Correct me if I'm wrong.</TD></TR></TABLE>
Where is the ignition coil located?
Old Jun 24, 2004 | 04:55 PM
mario82686's Avatar
What type of ignition does a 93 Civic EX have?
Old Jun 24, 2004 | 05:05 PM
Default Re: (mario82686)
that should be what your ignition coil looks like
Old Jun 24, 2004 | 05:09 PM
mario82686's Avatar
Default Re: (BrokeAssPinoy)
Which wire does the green tach wire connect to?
Old Jun 24, 2004 | 05:13 PM
first remove distributor cap so it would look like this http://www.overboost.com/pix.a...8.jpg
Old Jun 24, 2004 | 05:14 PM
mario82686's Avatar
Then what?
Old Jun 24, 2004 | 05:16 PM
connect to it the negative terminal which is the blue/white wire.
here's a simple schematic http://www.overboost.com/pix.a...m.jpg
Old Jun 24, 2004 | 05:17 PM
where the blue/white wire is connected to... that's the negative terminal, connect the green wire there
Old Jun 24, 2004 | 05:19 PM
JaeOne3345's Avatar
too much drama, **** the distributor..
Look near the firewall, driver side, near clutch/brake resevoirs you will see a service connector with a rubber plug covering it. tap into the blue wire running to this plug. it carries an RPM signal. i believe the plug is used by the dealership.
Old Jun 24, 2004 | 05:23 PM
Default Re: (JaeOne3345)
ahem ahem well I go by the manufacturer's recommended wiring set-up for a more accurate rpm reading.
Old Jun 24, 2004 | 05:31 PM
mario82686's Avatar
Isnt there a way to connect it by the cluster
Old Jun 24, 2004 | 05:33 PM
mario82686's Avatar
Or cant I just cut the blue wire and run it to the Autometer tach?
Old Jun 24, 2004 | 05:36 PM
JaeOne3345's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">ahem ahem well I go by the manufacturer's recommended wiring set-up for a more accurate rpm reading.</TD></TR></TABLE>
Believe me, it works fine. old trick anyway. Check the color of both wires (rubber connector vs. distributor), it might even be the same, i dont remember.
a1320honda's Avatar
yes, just tap into the blue wire behind the cluster. thats the factory tach wire. that will work
Old Jun 24, 2004 | 05:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaeOne3345 &raquo;</TD></TR><TR><TD CLASS="quote">
Believe me, it works fine. old trick anyway. Check the color of both wires (rubber connector vs. distributor), it might even be the same, i dont remember.</TD></TR></TABLE>
Yo Mario try doing what he said, I check my EJ6 and the wire from the ignition coil and the wire he's referring to is the exact same color. might actually work
Old Jun 24, 2004 | 05:40 PM
2lua's Avatar
driver side shock tower, there is a single blue wire with a plug that had a cap. hook the autometer rpm wire to it.
Old Jun 24, 2004 | 05:43 PM
a1320honda's Avatar
Default Re: (2lua)
theres no need to even pop the hood when doing a tach install. the blue wire behind the cluster the factory tach wire that feeds fron the dist. just use a wire tap on that wire.
Old Jun 24, 2004 | 06:01 PM
mario82686's Avatar
Default Re: (a1320honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda &raquo;</TD></TR><TR><TD CLASS="quote">theres no need to even pop the hood when doing a tach install. the blue wire behind the cluster the factory tach wire that feeds fron the dist. just use a wire tap on that wire.</TD></TR></TABLE>
Is this the best way?
Old Jun 24, 2004 | 06:03 PM
mario82686's Avatar
I looked at the distribtor and it was missing one wire
a1320honda's Avatar
yes, its the simplest and easiest, why run a wire to the engine compartment when its not necesary. thats my opinion. ive done several this way and no problems.
