gsr swap into ef.... GSR IM= what throttle cable?
Old Jun 24, 2004 | 02:50 PM
Charlie Moua's Avatar
Default gsr swap into ef.... GSR IM= what throttle cable?
ef hb si
gsr swap
stock gsr IM and TB bracket.
everyone told be to get a damn DA throttle cable. Now it seems like its about 4-5inches way to long before it will even bolt onto the bracket.
help
Old Jun 24, 2004 | 03:01 PM
ACRProject's Avatar
Default Re: gsr swap into ef.... GSR IM= what throttle cable? (Charlie Moua)
I think it would be best is you used the gsr throttle cable since your using a gsr tb/im. The 90-93 integra throttle cable is mainly used for the stock b16 manifold and the itr manifold.
Old Jun 24, 2004 | 03:03 PM
APEX CRX's Avatar
should asked me, remember I'm doing the same swap foo'!!!! J/K anyways I used a 94+ TEG cable and its perfect.
Old Jun 24, 2004 | 05:08 PM
jdm_ef9's Avatar
Default Re: gsr swap into ef.... GSR IM= what throttle cable? (APEX CRX)
i used a gsr one on my car. worked like a charm!
Old Jun 24, 2004 | 09:38 PM
Default Re: gsr swap into ef.... GSR IM= what throttle cable? (ACRProject)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACRProject &raquo;</TD></TR><TR><TD CLASS="quote">I think it would be best is you used the gsr throttle cable since your using a gsr tb/im. The 90-93 integra throttle cable is mainly used for the stock b16 manifold and the itr manifold.</TD></TR></TABLE>
now i know..
and everyone was telling me to get a damn DA one.
Well i got a DA one but i ended up being able to use my stock D16a6 throttle cable and it worked just fine best thing is that i didn't even have to ghetto rig anything.
the skunk2 IM is on the way so i can use the DA throttle cable later.
We fired her up (ef obd1 conversion) and it started right up. Only got code 9
import-tooner
Jan 25, 2011 05:30 AM
eggsi619
Jun 29, 2009 11:14 AM
DAmnquickDA
Jul 23, 2007 06:14 PM
1990_integra_DA9
Oct 29, 2006 06:25 PM
EVIL Hx Coupe
Mar 20, 2005 06:52 AM
