where is the a/c fuse
Old Jun 24, 2004 | 12:29 PM
huffer427's Avatar
Default where is the a/c fuse
Hello, I have a 1992 civic and I can not find the fuse for the air conditioning. Does anyone know where that might be? I can not find anything under the hood or in the fuse block to indicate that. Thanks
Old Jun 25, 2004 | 10:10 AM
SoCalB16a2's Avatar
Default Re: where is the a/c fuse (huffer427)
Okay. You need to start researching a little bit more before asking a question like this. I'm not trying to talk **** to you. But something like this is so simple and you can find out for youself. But I'll help you.
The fuse for the a/c relay is located under your driver side dash. Pop out the cover and it will give you a map of which fuses goes where. If you don't have one, I'll tell you. Look under the dash and look for a 10, 7.5 (from your left and 2nd row on the bottom) The 7.5 fuse is it. That should answer your question
eqrunner
Honda Civic (2016 - Current)
Aug 7, 2017 06:18 AM
P12 EG6
Nov 3, 2007 04:52 PM
Frost7177
Jul 6, 2007 03:44 PM
ahloung
12
Mar 16, 2006 08:00 PM
