Alarm wiring diagram
Old Jun 24, 2004 | 12:25 PM
sikteg's Avatar
Default Alarm wiring diagram
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 White/Black Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Neutral Safety Wire Green/White Gear Select Switch under Console
Brake Switch Green/White Brake Switch
Trunk Pin Green/Black (-) Above Fuse Panel Blue Connector
Parking Lights Red/Black Fuse Panel Green Connector
Head Lamp Red/White Light Switch
Hood Pin n/a
Factory Disarm Blue/White
Door Trigger Green/Red (-) Driver's Running Board One of Two
Wires
Door Lock Green/White (-) Behind Fuse Panel Gray Connector
Door Unlock Green/Red (-)
Horn Wire Blue/Green (-) Or Gray (-) at Steering Column
Windows Up LF=Blue/Red, RF=Blue/Yellow
Windows Down LF=Blue/White, RF=Blue/Green
There you go
EFPimpin
Audio / Security / Video
Sep 17, 2010 03:55 AM
4EN[sic]
Mar 9, 2007 05:09 AM
92GSRciv
10
Feb 8, 2007 05:29 AM
AznMTboy
Jun 27, 2005 05:25 PM
phillybeats.com
Jun 25, 2004 06:47 AM
