Where to Buy New TPS?
Old Jun 24, 2004 | 12:19 PM
blah116's Avatar
Default Where to Buy New TPS?
does anyone know where I can buy a TPS replacement for my 95 acura integra ls (automatic)? i would prefer new but old is okay too.
thanks!
blah116's Avatar
Default Re: Where to Buy New TPS? (blah116)
also, will a TPS taken off a '91 civic si work w/ my car?
Old Jun 24, 2004 | 12:34 PM
wilntegra's Avatar
well i was in ur shoes 2 days ago nobody sells tps by its self u have to buy the whole throttle body it comes together, i checked ebay ,dealer,and auto parts the only way to get one is buy going to a junk yard and finding one.....hope this helps cause it help me
Old Jun 24, 2004 | 12:37 PM
hypa's Avatar
wilntegra is right.
No one I've ever found sells the TPS alone. Try to contact some auto wreckers and you might get lucky.
Old Jun 24, 2004 | 01:52 PM
Kendall's Avatar
Honda/Acura only sells the TPS with the throttle body as an assembly. The good news is that pretty much all Honda TPS's are 100% compatible with each other. Find a TPS from an old D series and you'll be set.
Old Jun 24, 2004 | 10:11 PM
93RS's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Honda/Acura only sells the TPS with the throttle body as an assembly.</TD></TR></TABLE>
Thats a roger!
Old Jun 24, 2004 | 10:17 PM
esponet's Avatar
yup check your local wrecking yards.
any honda tps should do. the reason honda don't sell it seperatly is that they need to be calibrated to your t/b. if set wrong then you could wind up with mixture problems. so when you get a replacement one make sure to calibrate it properly.
Old Jun 24, 2004 | 10:36 PM
blah116's Avatar
thanks for all the replies. hm i called an acura dealer today and he said he had it in stock for $50 which i thougth was weird b/c i called other dealers and they also said you have to buy the whole tb. i guess i'll call again to confirm : /
Old Jun 24, 2004 | 10:52 PM
esponet's Avatar
it is available through other counties. so its possible that a certain dealer get a hold of them then sell it as a aftermarket product. defenetlly not oem.
Old Jun 24, 2004 | 11:09 PM
Mad Cow's Avatar
They are sorta riveted on there too, as I recall... hard to take off. You have to use a cutting wheel or some other sort of tool to cut a notch, then unscrew with a flat head screwdriver.
Old Jun 24, 2004 | 11:10 PM
blah116's Avatar
Default Re: (esponet)
oh. should i go w/ an oem used tps or a new non oem then?
Old Jun 25, 2004 | 07:47 AM
esponet's Avatar
either one would work fine. used oem, or aftermarket, just make sure its still in good condition. but i think used oem are cheaper and sometimes free from the wrecking yard.
Old Jun 25, 2004 | 10:05 AM
blah116's Avatar
just called acura again and turns out he was looking at the wrong part. they only sell the whole tb. guess i'll buy a used one for about $20
Old Jun 25, 2004 | 10:28 AM
mr.beeks's Avatar
Default Re: (blah116)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah116 &raquo;</TD></TR><TR><TD CLASS="quote">just called acura again and turns out he was looking at the wrong part. they only sell the whole tb. guess i'll buy a used one for about $20</TD></TR></TABLE>
for $20 you get the screws that hold it to the throttle body.....
LOL
mjf6866
Jul 22, 2010 08:29 PM
alkeener
Oct 26, 2003 07:25 PM
roadrunner
Nov 25, 2002 08:53 AM
FUP23
Aug 3, 2002 06:00 PM
fixhondas
Feb 8, 2002 11:17 AM
