Overheating in traffic???
Old Jun 24, 2004 | 11:29 AM
CRXed's Avatar
Default Overheating in traffic???
Okay, my car has overheated 4 times in the past few monthes, causing coolant to spew all over the engine bay. This last instance leaves me with a cracked radiator. The overheating only occurs when im sitting in traffic! I can tear it up all night, but its only at a standstill that the problems occur. I suspect a bad water pump, but anyone else care to drop some comments?
Old Jun 24, 2004 | 11:36 AM
Redline130's Avatar
Default Re: Overheating in traffic??? (CRXed)
Is your fan working?
Old Jun 24, 2004 | 11:38 AM
Footwork's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXed &raquo;</TD></TR><TR><TD CLASS="quote">Okay, my car has overheated 4 times in the past few monthes, causing coolant to spew all over the engine bay. This last instance leaves me with a cracked radiator. The overheating only occurs when im sitting in traffic! I can tear it up all night, but its only at a standstill that the problems occur. I suspect a bad water pump, but anyone else care to drop some comments?</TD></TR></TABLE>
set the heater to max hot and blast it when in traffic.
watch the needle go down.
not the answer, but a band aid until you fix it.
my ef9 (b16) w/ stock radiator used to do that a lot.
Old Jun 24, 2004 | 11:40 AM
APEX CRX's Avatar
Default Re: Overheating in traffic??? (Primo.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Primo. &raquo;</TD></TR><TR><TD CLASS="quote">
my ef9 (b16) w/ stock radiator used to do that a lot.</TD></TR></TABLE>
water pump problem
Old Jun 24, 2004 | 11:41 AM
CRXed's Avatar
Yes, the fan is working. And the thing is, there is no impending sign of disaster, as the "needle" never goes beyond halfway until AFTER the spewing, then it shows hot.
Old Jun 24, 2004 | 12:58 PM
Full Race A6's Avatar
Default Re: (CRXed)
First Id say fan if it only happens in traffic, but you say its working
Little JB weld will seal the crack in the rad if it isnt to bad
Sounds like you might need a water pump though
Old Jun 24, 2004 | 01:35 PM
civickiller's Avatar
Default Re: (W O T)
well sinec you got the new radiator does it still do it ? im guessing it still does.
i would cahnge the thermostat and water pump and T belt
Old Jun 24, 2004 | 03:28 PM
Steemo's Avatar
Default Re: (civickiller)
definitely make sure the fan is working. and check the thermostat. sometimes they stick and dont work properly and cause all kinds of problems, but the good thing is if it is the thermostat then its a cheap fix.
Old Jun 24, 2004 | 05:11 PM
deftones0817's Avatar
Default Re: (Steemo)
i had same problem but it turned out my fan was unplugged after swap. YOu sure its work and not your ac fan that you see turning on and off. Check to make sure both fans are working.
DEF
Old Jun 24, 2004 | 08:47 PM
MonkeyMagic's Avatar
Default Re: (CRXed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXed &raquo;</TD></TR><TR><TD CLASS="quote">Yes, the fan is working. And the thing is, there is no impending sign of disaster, as the "needle" never goes beyond halfway until AFTER the spewing, then it shows hot.</TD></TR></TABLE>
definately sounds like your thermostat is sticking
Old Jun 24, 2004 | 09:34 PM
91hob20hb's Avatar
Default Re: (MonkeyMagic)
I agree sounds like thermostat.I had the same problem a few weeks ago it would start to overheat while sitting in traffic,but once i got air flowing through the radiator as i drove the temp would fall back down and then raise up again while i was sitting still.
Old Jun 24, 2004 | 10:13 PM
CRXed's Avatar
Replaced the thermostat today, radiator goes in tomorrow. Guess i'll let you guys know if it crunks on me again.
raider1qaz
Feb 21, 2013 07:06 AM
AcuraFanatasism
Sep 20, 2009 02:55 PM
jeremyrocksursox
Jul 14, 2009 11:53 PM
hatchman88
May 30, 2009 05:50 PM
SupaFly_Honda
Oct 21, 2003 08:33 AM
