EMERGENCY EF guys help FAST.. doing swap right now!!!
Old Jun 24, 2004 | 11:21 AM
Charlie Moua's Avatar
Default EMERGENCY EF guys help FAST.. doing swap right now!!!
ef hb si
gsr swap
hasport hydro kit....
what vss do you use? my ef one seems kinda short... i might pop out while driving.
can i use the DA one? how do you take it off behind the fire wall?
also my fuel filter is rusty and the fuel bolt won't come off. what to do?
do i use the EF fuel returne line or the GSR one?
Old Jun 24, 2004 | 11:26 AM
slywfbpsi's Avatar
Default Re: EMERGENCY EF guys help FAST.. doing swap right now!!! (Charlie Moua)
If you are doing a hydro kit swap, you have to use a electronic vss from a 94+ integra or 92+ civic. to pull out the stock vss from the firewall you dissconnect it from the tranny and pull it out from inside the cabin. Have you tried using wd40 on the rusted bolt? letting it sit for a while? even trying to brush some of the rust off with a wire brush to get a better grip on it? you can use the ef return line.
Old Jun 24, 2004 | 11:35 AM
Default Re: EMERGENCY EF guys help FAST.. doing swap right now!!! (slywfbpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi &raquo;</TD></TR><TR><TD CLASS="quote">If you are doing a hydro kit swap, you have to use a electronic vss from a 94+ integra or 92+ civic. to pull out the stock vss from the firewall you dissconnect it from the tranny and pull it out from inside the cabin. Have you tried using wd40 on the rusted bolt? letting it sit for a while? even trying to brush some of the rust off with a wire brush to get a better grip on it? you can use the ef return line.</TD></TR></TABLE>
thanks
so i CAN... use the ef stock fuel return line, just to get my car up and running RIGHT?
hasport said that i should use the Bseries one.... (nothing about i must)hehe
thats fine cause i have stock exhaust/cat and have to break in my new clutch so i won't be hammering it or anything..
Old Jun 24, 2004 | 11:45 AM
Rywire's Avatar
You dont have to use a electronic vss.
Old Jun 24, 2004 | 11:48 AM
civickiller's Avatar
Default Re: EMERGENCY EF guys help FAST.. doing swap right now!!! (droppedcrxsi)
yeah you dont have to use the electronic vss.
and i just changed my fuel filter and i couldnt get the feed line botl out so i just put my impact to it and it came free easy
Old Jun 24, 2004 | 11:57 AM
ghettocrxsi's Avatar
Default Re: EMERGENCY EF guys help FAST.. doing swap right now!!! (civickiller)
The fuel filter is stuck on there. Try and get a breaker bar and get it free.
Also the return line you should use what ever one fits the best.
The vss you don't have to use the electronic vss. If you do you need to swap out to a cluster that uses electronic vss such as integra 94+ or jdm sir.
Old Jun 24, 2004 | 12:08 PM
vitrox's Avatar
i'm suprised nobody mentioned spraying a ton of pb blaster on that bolt and letting it sit for a while, then bust it off.. pb owns j00
Old Jun 24, 2004 | 12:48 PM
Default Re: (vitrox)
yeah i understand that i don't use the gsr vss (elevtrical) unless i'm putting a EG/EK/DC cluster in.
my only concern is that it might pop out during racing... (ie) no speedo no vtec.. hehe
Old Jun 24, 2004 | 01:08 PM
slywfbpsi's Avatar
Default Re: (Charlie Moua)
then just get a da on from a b18a or b17, may have the extra length in it that you need.
Old Jun 24, 2004 | 02:44 PM
Default Re: (slywfbpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi &raquo;</TD></TR><TR><TD CLASS="quote">then just get a da on from a b18a or b17, may have the extra length in it that you need.</TD></TR></TABLE>
i though they were the same length?
hey i have another problem now.....
I'm using the GSR IM and bracket. People said to get a DA throttle cable. I hooked it up and it seems to be abou 5inchs too long. WHats the deal
GSR EF guys help me out/...
Old Jun 24, 2004 | 03:10 PM
eda6's Avatar
I had that problem with the throttle cable being too long.
Installed 98 type r throttle cable into 88 dx hatch.
I shortened the cable. I made it work.
Take out the excess and reconnect with an electrical coupling
Do this and problem solved.
Old Jun 24, 2004 | 03:52 PM
Nature's Renewal's Avatar
Default Re: (eda6 hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 hb &raquo;</TD></TR><TR><TD CLASS="quote">I had that problem with the throttle cable being too long.
Or you could just make a custom bracket like I did when I ran into that similair problem
Old Jun 24, 2004 | 09:48 PM
Default Re: (krskid)
thanks guys... i just started her up like 30min ago.
obd1 conversion sucsess. only threw code 9 only gsr (p72ecu)
what is code 9?
Also FYI.... when doing gsr swap into ef & using the stock GSR IM use your stock D16a6 throttle cable NOT DA
DA will only work with ITR/B16 style IM
Old Jun 24, 2004 | 10:05 PM
buckNasty's Avatar
glad u got it going man
good luck on it
and on my itr intake i just had to move the throttle cable bracket so only one bolt held it down but it works fine now, oh yeah da in a 89 hatch
Old Jun 25, 2004 | 03:56 AM
FourthGenHatch's Avatar
Default Re:
I used my 3/8 impact to take off the fuel filter bolts because the filter always tries and rotate around when you turn the bolt by hand. I had to take my cat converter off my exhaust that was here at my house and the bolts were all rusty. I had to take them off by hand. Took me like 20 minutes for 3 bolts. If I had it at work where my good tools are I would have zapped it off with an impact in about 30 second total.
Old Jun 25, 2004 | 04:40 AM
Default Re: Re: (FourthGenHatch)
Your vss will not fly out while racing. That is one of the dumbest things that I've heard today.
You can use a d or b series vss. They will hold the same, just use the 10 mm bolt and the little clip that holds the speedo cable on. lol
Glad its running good for ya
code 9 CYP - cylinder sensor
Old Jun 25, 2004 | 06:28 AM
Default Re: Re: (ghettocrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettocrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Your vss will not fly out while racing. That is one of the dumbest things that I've heard today.
code 9 CYP - cylinder sensor </TD></TR></TABLE>
well the vss cable is so damn tight, theres no play in it at all. I mean even with the pin to hold it in, don't you think there could be a chance of it poping out?
well code 9 CYP..... i think it's because the timing is all the way advanced for some reason. Also i have crudy 87 octane and and old fuel filter.. hehe
Josh Prezbind
Mar 11, 2018 07:20 AM
joshii_honda
Jan 27, 2015 04:54 PM
freitasfamily09
Classic Hondas
Feb 9, 2010 04:06 PM
sanchito6
Apr 29, 2006 05:57 PM
Charlie Moua
45
Jul 30, 2004 11:18 AM
