Going 17s... Stop me.
Forgot about the flaming. Updated:
- Bigger rotational mass ---> Effect is not that big as to avoid 17s
- Expensive tires ---> $10 more per tire
- Flaming ---> thats always.
- Heavier Wheels ---> About 5 pounds per set.
I dont think they look bad at all, and unless you are drag racing or serious track racer, then go for it. Otherwise you probably wont notice much if any difference. If you got the wallet, go for it.
i always thought they looked a little too big on the integra. You will have wayyyyy more tire choices, that is a good thing. About them not being much slower, you will DEFINITELY be able to tell you have 17's on. I can feel the difference when I switch from lighter than OEM 16's to OEM 15's. 15's do indeed feel quicker but this could be attributed to older more worn tire treads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia »</TD></TR><TR><TD CLASS="quote">Nothing wrong with 17's :D
But I'd stick to 16's with an ITR.</TD></TR></TABLE>
Exactly.
Exactly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Champ R »</TD></TR><TR><TD CLASS="quote">16's look just about right on an ITR, but if you are hell bent on 17's, make sure they are a lightweight set.</TD></TR></TABLE>
Wut he said. Personally I see no need to upgrade from the stock gunmetal 15's. But this is not about me...good quality and light weight 17's are pretty pricey
