Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Over inflating a tire
Old Jun 24, 2004 | 10:00 AM
LX4CYL's Avatar
Default Over inflating a tire
My 195/65-15 Michelin Energy MXV4s rollover all the time whenever I auto-x
(0+ camber up front). It states on the sidewall that I cannot put more than 44PSI, but do you think I can get away with, let's say 48-50PSI for my front tires, or could they pop?
Old Jun 24, 2004 | 10:45 AM
philstireservice's Avatar
Default Re: Over inflating a tire (LX4CYL)
I wouldn't recommend it. They will still probably rollover. They are just not designed for auto-x.
Old Jun 24, 2004 | 10:50 AM
Big Phat R's Avatar
your problem is sidewall height. 65 series tires are like snow-tire aspect ratio.
adding more air will decrease traction and performance as well
you need better tires
WRXRacer111's Avatar
Default Re: Over inflating a tire (Maxx44)
YMMV, but I used to run Hoosiers at 65psi in the rear of my WRX to make it rotate on autox courses. Ran up to 72psi on my stock Bridgestone RE92s to make it rotate. My tires didn't explode, though that's not to say yours won't for some reason.
Old Jun 24, 2004 | 10:59 AM
LX4CYL's Avatar
Default Re: Over inflating a tire (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">you need better tires</TD></TR></TABLE>
duh!
I'm trying to stay on bad tires as loooong as possible, and I'll even pay the $32 to have them remounted side to side so I can get more out of them. Ever since I switched back to these wheels/tires from 225/40-18 ES100s, I've found that I'm now actually learning how to drive...
Old Jun 24, 2004 | 01:55 PM
eliktronik's Avatar
I had the same exact problem with the 205/60-15's on my old altima. My goal was to just drive it, focus on being smooth and learning not to over-drive it.
Old Jun 24, 2004 | 07:09 PM
fidracer's Avatar
Default Re: Over inflating a tire (eliktronik)
I've safely run upwards of 60psi cold in street tires on the track.
wezzel19
Oct 31, 2008 05:23 PM
SFlCrx
Nov 4, 2007 12:08 PM
TorquelessB16
Oct 4, 2006 05:14 PM
ap1$2k
Honda S2000
32
Sep 9, 2006 05:26 PM
Curtisbeef
Aug 12, 2005 05:53 PM
