D16a6 with D16y8 head...head studs?
like the title says i have a d16a6 matched up with a d16y8 vtec head. which arp head studs do i use? thanks for the help
the only ones offered on their site are:
Civic D16Y 208-4305
Honda D16Z - Only 208-4301
Civic D16Y 208-4305
not sure about A6 + Y8 but....
I have a Z6 head + Y8 block and ARP z6 studs..... They all fit but one, which was replaced by a stocker.
That doesnt answer your question, but may help put you in the right direction
I just assembeled my a6 y8 mini me and i used y8 studs... They all fit but one and it was to long so I cut it to the right length. The z6 studs are shorter and wont even come out of the top of the head. Also the reason the one bolt is to long is because the hole in the block isnt deep enough but the a6 head makes up for that by making the bolt sit up higher in one spot, so you need to cut the last bolt shorter for the y8 head since it dosnt compensate for the smaller hole in the block like the a6 head.
B_Swapped93
Mar 22, 2014 07:25 AM
Cruiser G
Sep 19, 2009 09:43 PM
red civic standard
Mar 26, 2007 07:56 AM
