code 10 14 after mpfi-and mini me
Old Jun 24, 2004 | 09:42 AM
Layziebtnh055's Avatar
Default code 10 14 after mpfi-and mini me
anyone know why i would get these codes i know what they are but why??all my plugs are in the right place im pretty sure
Old Sep 22, 2005 | 06:53 AM
Servo's Avatar
Default Re: code 10 14 after mpfi-and mini me (Layziebtnh055)
Bringin this back from the dead because I got the same two codes. Funny because I didn't rewire either of those plugs. And the manifold came off of a running car. Did I really just get lucky enough that both sensors went bad?
I already tried cleaning them off with Carb cleaner and resetting the ECU. No luck.
Old Sep 22, 2005 | 06:54 AM
Servo's Avatar
Default Re: code 10 14 after mpfi-and mini me (Servo)
This is just an MPFI swap, BTW...
Old Sep 22, 2005 | 07:05 AM
blah13's Avatar
Usually when people throw these its because they swapped the connectors...these 2 and the tps can be interchanged b/c they have the same plug. Swap them around and try it, I've yet to have an AIT go bad, 3 hondas all over 200k miles....
Old Sep 26, 2005 | 06:08 AM
Servo's Avatar
Sorry for delayed response... I'll try that right away. I had no clue that they were the same plug. Guess I should have looked closer.
Old Sep 28, 2005 | 06:47 AM
Servo's Avatar
You were right. It was just the plugs. I had the IAT plug on the EACV and the 'leftover' plug on the IAT. Swapped them around and now the car runs just fine with no codes. Thanks for the help!
Beau Gotti
May 28, 2007 08:42 AM
2fast4udude
16
May 4, 2006 09:50 PM
volkracing99
Dec 2, 2002 09:49 PM
AutoboTxEK
Apr 3, 2002 09:49 AM
98R #448
Jan 2, 2002 07:02 AM
