195/50 or 205/50
I recently put 205/50 Azenis on stock rims, and I dont think its bad at all. 195/55 RE010's have slightly faster turn in, but its not a very noticable difference IMO.
I would shy away from 195/50 for saftey reasons.
Don't be afraid to use 195/50R15. The difference in max. load is not that big. The weight of the ITR is well within the safety margins.
For example:
195/55R15 RE-010, max load = 1102 lbs per tire
195/50R15 S-03PP, max load = 1047 lbs per tire
The difference is only 55 lbs per tire!!!!!
Modified by DutchITR1689 at 9:00 PM 6/24/2004
For example:
Like someone said above me the "safety" issue doesn't really exsist with 195/50's unless you plan on cornering with 4 people in the car and a stuffed trunk.
195/50's will provide the sharpest response on the stock rims while also slightly raising the final drive (which is good). Not to mention they will also be lighter and cheaper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero »</TD></TR><TR><TD CLASS="quote">Like someone said above me the "safety" issue doesn't really exsist with 195/50's unless you plan on cornering with 4 people in the car and a stuffed trunk.
195/50's will provide the sharpest response on the stock rims while also slightly raising the final drive (which is good). Not to mention they will also be lighter and cheaper. </TD></TR></TABLE>
Why 195/50 wilol provide the sharpest reponse??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam »</TD></TR><TR><TD CLASS="quote">
Why 195/50 wilol provide the sharpest reponse??</TD></TR></TABLE>
lower sidewall -> less flex
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 »</TD></TR><TR><TD CLASS="quote">
lower sidewall -> less flex</TD></TR></TABLE>
That too but in comparison to 205/50's the 195's will fit the rim slightly better.
I actually went back to 195/50/15's from 205/50/15's and I'm much more pleased with the smaller tire. The cars feels less "bland" under hard cornering and is a bit easier to predict.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero »</TD></TR><TR><TD CLASS="quote">195/50's will provide the sharpest response on the stock rims while also slightly raising the final drive (which is good). Not to mention they will also be lighter and cheaper. </TD></TR></TABLE>
Basically like getting a free JDM final drive with your tires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor »</TD></TR><TR><TD CLASS="quote">Will the tire rub with a 195/55 with the car lowered?</TD></TR></TABLE>
Well, that is the size that comes stock. Unless you are extremely low, i doubt it will rub.
