installing a car alarm....!
I am installing a new car alarm in my 93 del sol..
as I got ready I noticed that the fuse panel didn’t have that sheet I needed to do so. I want to know is there anyone that has the diagram to share? or know of which wires are which?
I need to locate the ignition wire along with the parking lights . Any help would be great thanks!
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 White/Black Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Neutral Safety Wire Green/White Gear Select Switch under Console
Brake Switch Green/White Brake Switch
Trunk Pin Green/Black (-) Above Fuse Panel Blue Connector
Parking Lights Red/Black Fuse Panel Green Connector
Head Lamp Red/White Light Switch
Hood Pin n/a
Factory Disarm Blue/White
Door Trigger Green/Red (-) Driver's Running Board One of Two Wires
Door Lock Green/White (-) Behind Fuse Panel Gray Connector
Door Unlock Green/Red (-)
Horn Wire Blue/Green (-) Or Gray (-) at Steering Column
Windows Up LF=Blue/Red, RF=Blue/Yellow
Windows Down LF=Blue/White, RF=Blue/Green
Theres your wiring diagram
Hood Pin n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueturbo4door »</TD></TR><TR><TD CLASS="quote">you should still always check them with a multimeter
also all hondas have a parklight term. on fusebox [ one of the inset flat male spade conn. ]. 94
AznMTboy
Jun 27, 2005 05:25 PM
