obd1 motor = obd1 alternator?
Old Jun 24, 2004 | 09:18 AM
mjrage's Avatar
Default obd1 motor = obd1 alternator?
I need an alernator, well rebuild, reman, whatever.
Since the motor is a b16 obd1, car is obd2, the alternator HAS to be obd1? or will a 99-00 si obd2 alternator work?
Old Jun 24, 2004 | 09:33 AM
Built to Spill's Avatar
el diablo
Default Re: obd1 motor = obd1 alternator? (mjrage)
I know its possible to wire an obd1 alternator into an obd2 wiring harness, but not 100% sure on the exact wiring instructions (if there is any) for your obd1 harness to get the obd2 alternator to work.
Old Jun 24, 2004 | 09:37 AM
mjrage's Avatar
Default Re: obd1 motor = obd1 alternator? (Built2Spill)
i am using an obd2 ex harness, and an obd2 - 1 conversion.
Does that mean I dont have to rewire for it?
Old Jun 24, 2004 | 09:42 AM
el diablo
I was reading a thread earlier where advanracing62 on this board wired an obd2 wiring harness to an obd1 alternator. If you already have an obd2 wiring harness then i <U>believe</U> an obd2 alternator should work.
Old Jun 24, 2004 | 09:53 AM
delScho's Avatar
It's possible. I built a big wiring harness out of an OBD1 and an OBD2 put together. It still needs an OBD1 ecu, but I can use either a 1 or 2 alternator/dizzy/injectors. I even wired in a resistor box option so I can run low or high impedence injectors either style. Took some extra time to do, but it has been infinitely helpful in my options for parts and last second replacements when need be.
But yes, the alternator will work if wired correctly. I would just recommend against cutting the old plug off when you could just splice in with the option to maybe run a different alternator later.
Next step is splicing in a GM 3 bar map sensor plug.
sebTeggy
Feb 10, 2012 04:52 PM
ekmotorfiend
Jan 5, 2008 06:20 AM
cthan3o3
13
Jul 31, 2005 08:27 AM
mjrage
Jun 29, 2004 07:51 AM
