accord tranny fliud question
Old Jun 24, 2004 | 08:50 AM
tsdenny's Avatar
Default accord tranny fliud question
hi, i am planning on flushing my tranny fluid soon. i search the forum and found that some people prefer Honda MTF. i have a 2001 auto accord. i know they've been known to have tranny problems, so i want to know whats the best fluid to use. so is the Honda MTF the best way or is there anyone out there i should try.
thanks in advance
Old Jun 24, 2004 | 08:54 AM
89_LXi's Avatar
Default Re: accord tranny fliud question (sleepalotx)
Uhhh.... Honda manual transmission fluid probably won't work too good in your auto But Honda ATF is good stuff and your tranny will thank you for it
Old Jun 24, 2004 | 09:16 AM
spankey167's Avatar
Default Re: accord tranny fliud question (89_LXi)
Honda ATF my friend... Not to thread jack but i had a question about measuring the tranny fluid... The motor should be normal operating temperature. But should the dip stick be checked by pushing the dipstick all the what down until its in place or just enough before it needs to be pushed down? And some people say the measurement should be in the middle of the hashes and some say until the line... Anyone know the right way of checking? Thanx
Old Jun 24, 2004 | 10:11 AM
Elvis1977's Avatar
Default Re: accord tranny fliud question (spankey167)
Push the dipstick all the way down. Fluid can be at the top marker OR in the safe area. DO NOT OVERFILL OR UNDERFILL. also, make sure the engine is off and on level ground when checking.
Old Jun 24, 2004 | 10:19 AM
spankey167's Avatar
Default Re: accord tranny fliud question (Elvis1977)
The hashes is what you mean by safe area correct?
Old Jun 24, 2004 | 10:31 AM
Elvis1977's Avatar
yes. also the longer you let the car sit on a level plane with the engine off while adding fluid the better. In other words, add fluid and WAIT a while before checking level.
Old Jun 26, 2004 | 06:42 AM
Elvis1977's Avatar
Old Jun 26, 2004 | 09:52 AM
Confuc1ous's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elvis1977 &raquo;</TD></TR><TR><TD CLASS="quote">.</TD></TR></TABLE>
wow, easy way to up your post #, uhm, stick with the regular tranny fluid, the one that is recommended for your car, its usually always the best unless you've done super extensive mods to your transmission which require a better fluid, until then, Honda trans. fluid is the way to go!
PA07
Transmission & Drivetrain
Oct 10, 2014 10:46 PM
bonbon
Jun 23, 2005 08:48 AM
JMD
May 17, 2004 11:56 AM
DavidTurbo
Aug 8, 2003 07:31 AM
DrunkNRacer
May 8, 2003 11:45 AM
