Help! Clutch won't allow shifting into any gear.
Old Jun 24, 2004 | 01:23 AM
joestud's Avatar
Default Help! Clutch won't allow shifting into any gear.
Does anyone know what the possiblities are? Is it a bad pressure plate, clutch, etc? I won't let you shift into any gear if you start in neutral. The clutch fork is moving the throwout bearing. Any ideas?
Joe
Old Jun 24, 2004 | 03:50 AM
DevoZ's Avatar
Default Re: Help! Clutch won't allow shifting into any gear. (joestud)
check your clutch fluid reservoir...
Old Jun 24, 2004 | 04:37 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joestud &raquo;</TD></TR><TR><TD CLASS="quote">... The clutch fork is moving the throwout bearing. Any ideas?</TD></TR></TABLE>That means the hydraulics are OK. So you'll have to pull the tranny & look. Broken pressure plate??
fminusmic
14
Feb 1, 2022 05:07 PM
EG_LS
15
Sep 3, 2007 06:01 PM
wrx'n you
22
Oct 26, 2006 06:28 PM
vietnamese0utlawz
Oct 11, 2006 04:53 PM
KillaB18
Apr 21, 2005 08:43 PM
