Flex pipe dilemma...
Old Jun 23, 2004 | 11:51 PM
LHC's Avatar
LHC
Default Flex pipe dilemma...
I will be soon buying a jdm 4-1 mating to a high flow cat and im wondering whether i need a flex pipe. is it necessary or just overkill?
At the same time i will be installing a custom 2.5" catback with a magna oval.
My setup is a b18c1 in a 92 EG.
Anyt help would be much appreciated.
Old Jun 23, 2004 | 11:57 PM
Eddiebx's Avatar
ideally a flex pipe would be best, if you dont mind hacking up ur brand new header, and have the room for a flex pipe definitely weld one in. if not you can get away with using those donut gasket type things to get aroudn the flex pipe, but they dont seal as good.
but in any event, please have some sort of flex section in there, be it a flex pipe or a donut gasket, because if you dont' i gurantee you cracked welds in ur exhaust system in no time.
Old Jun 24, 2004 | 12:10 AM
LHC's Avatar
LHC
Default Re: (Eddiebx)
well the guy selling me his setup comes with jdm itr 4-1, flex pipe and 2.5" high flow cat for a decent price. so i'll be getting one reagrdless
Modified by LatinoHatchCrap at 7:27 PM 6/24/2004
Old Jun 24, 2004 | 12:24 AM
k_spek's Avatar
Default Re: (LatinoHatchCrap)
I would stay away from flex pipes. They are not smooth inside and do not flow very well. Plus flex pipes tend to crack over time on the inside, resulting in exhaust leaks.
Running with a donut gasket and spring bolts should allow the engine to flex and torque as needed. That's my recommendation.
Old Jun 24, 2004 | 12:42 AM
LHC's Avatar
LHC
Default Re: (laugHin22CX)
so maybe i should look at not getting a flex pipe and just ditchin this guys setup!
brandobot89
Jun 2, 2008 11:12 AM
MopdiT
Feb 4, 2008 12:48 PM
B16CRXT
Mar 14, 2005 02:34 PM
tonezilla
Welding / Fabrication
Feb 15, 2005 07:17 AM
optikal_blitz
Feb 11, 2004 10:22 AM
