2.2.5 to 2.5" exhaust piping? good/bad/whatever?
Old Jun 23, 2004 | 10:18 PM
Tad's Avatar
Tad
Default 2.2.5 to 2.5" exhaust piping? good/bad/whatever?
Ok so i'm planning on running my buddies ITR piping for exhaust,
but I"m thinking i'll get a universal and some 2.5" piping from the axle back.
is this .25" step up in diameter a problem at all? or is it just freer flowing at the end?
I know they use stepped designs in headers occasionally,
but I dont think i've seen it in exhaust..
sounds good to me, but I wanted to hear what the ht folk thought first.
thanks.
Old Jun 23, 2004 | 10:24 PM
Luserkid's Avatar
Default Re: 2.2.5 to 2.5" exhaust piping? good/bad/whatever? (Tad)
You wont have any problems, if thats what your asking. For Gains, i dont think youll get that much, or any for that matter because its still restricted air from the cat to the axle back.
Atleast thats how i see it being. I would just do a whole 2.5 exhaust.
Old Jun 24, 2004 | 12:19 AM
Skynet's Avatar
looks good , bad for your engine
Old Jun 24, 2004 | 07:31 AM
gEEd93hatch's Avatar
def not good. whats the size piping we should use on a B18b?.. 2.25" OR 2.5" I think i might have even bigger than that. its rediculously big. i have a feeling it might be 2.75" or 3" even. the car used to have nitrous and almost seems as if its too wide open. suggestions welcome?
Old Jun 24, 2004 | 07:40 AM
uncle's Avatar
Default Re: (gEEd93hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gEEd93hatch &raquo;</TD></TR><TR><TD CLASS="quote">def not good. whats the size piping we should use on a B18b?.. 2.25" OR 2.5" I think i might have even bigger than that. its rediculously big. i have a feeling it might be 2.75" or 3" even. the car used to have nitrous and almost seems as if its too wide open. suggestions welcome?</TD></TR></TABLE>
#1. unbolt the exhaust
#2. measure the diameter of the piping
#3. don't hijack someone else's thread
Old Jun 24, 2004 | 08:39 AM
Tad's Avatar
Tad
Default Re: (uncle)
a note,
the engine i'm going to be running is a jdm d15b,
the ITR piping will be perfect for it n/a,
I wouldnt run 2.5
but i might put my turbo kit on one of these days..
so 2.5 would be nice.. just swap out the center piping.
Old Jun 24, 2004 | 11:05 AM
Skynet's Avatar
"so 2.5 would be nice.. just swap out the center piping" ? arent you goan weld on the 2.5 itr?
Old Jun 24, 2004 | 11:08 AM
pdiggitydogg's Avatar
its not going to make any difference going from 2.25" to 2.5"....hurting-wise
I thought the b18b's were 2.5 at the header anyways...no?
Old Jun 24, 2004 | 06:25 PM
Tad's Avatar
Tad
Default Re: (Skynet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skynet &raquo;</TD></TR><TR><TD CLASS="quote">"so 2.5 would be nice.. just swap out the center piping" ? arent you goan weld on the 2.5 itr? </TD></TR></TABLE>
no,
the ITR piping is 2.25, and it runs from the cat to the axle,
should bolt up fine,
then from the axle back it will be 2.5,
which will need some welding cuz i'll do a custom rig.. probly just get some mandrel bends and cutem/weldem to get the proper piping,
with a univerasal muffler.
CRX MASE
Dec 6, 2004 02:47 PM
Volcom
May 4, 2003 12:13 PM
Rory Breaker
Dec 11, 2002 10:43 AM
.Ryan
Oct 4, 2002 09:46 PM
Eggman
Dec 11, 2001 10:47 PM
