b16 redline
Old Jun 23, 2004 | 05:50 PM
ricebrnr13's Avatar
Default b16 redline
i have a 1990 civic with a jdm sir b16. i just got the motor in and it keeps cutting out at about 7200 rpm's. other than that it seems to run good, any ideas?
Old Jun 23, 2004 | 06:13 PM
Two_K Si's Avatar
Default Re: b16 redline (ricebrnr13)
Had any check engine lights? Do you know what ECU you have?
Old Jun 23, 2004 | 06:29 PM
redline32's Avatar
sounds like you got the sohc computer, it should rev till 8200 fuel cut
Old Jun 23, 2004 | 06:43 PM
SleepnCiViC's Avatar
Old Jun 23, 2004 | 06:48 PM
ricebrnr13's Avatar
the check engine light comes on at around 3000 rpm's and syays on untill its turned off, the ecu is a pr3
Old Jun 23, 2004 | 06:53 PM
FERIOkid's Avatar
holy **** a newbie that asked a real question... congradulations, welcome to honda-tech you should learn a lot here.
The only thing i can think of is that your ecu is potentially bad or there is a simple wireing problem you have to sort out
Old Jun 23, 2004 | 07:20 PM
redline32's Avatar
Default Re: (SleepnCiViC)
my b16 redlines at 8100 but fuel actually cuts at 8250 on the autometer, could vary tach to tach i guess
Old Jun 23, 2004 | 07:25 PM
Kamin's Avatar
Default Re: (redline32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redline32 &raquo;</TD></TR><TR><TD CLASS="quote">my b16 redlines at 8100 but fuel actually cuts at 8250 on the autometer, could vary tach to tach i guess</TD></TR></TABLE>
fuel cut is higher than redline.
Old Jun 24, 2004 | 07:13 AM
JDMSiGuy17's Avatar
Default Re: (Kamin)
I have an Si and mine redline hit at 8200, hope this helps you. But it does sound like something is wrong with your ECU.
EJ1_228
Mar 29, 2006 08:15 AM
teler86
14
Nov 27, 2004 01:26 PM
kagegod
Aug 2, 2004 06:39 PM
insomniac791
23
Nov 14, 2003 07:55 AM
TooDrunk2See
Oct 21, 2003 04:36 PM
