1993 Honda Civic Dx snapped valve cover bolt
spec are NOT 73 or 83....those bolts will snap at like 22!!!!!
go to honda...take valve cover off again....get 12mm deep socket...take old one out...put new one in...
dude read your book it clearly states at the top that it is in inch pounds, and if you had the right tourqe wrench then it should of been fine i think you were using a regular tourqe wrench and you were using foot pounds not even close to the same so chad was correct in what he said next time read your manual more carefull
its only hard the first time and after that, itll take ya only like 20 min to change them, better than payin honda 150 -200 a pop (i change mine all the time just to be safe) just have a book and follow the directions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KarbinFourteen »</TD></TR><TR><TD CLASS="quote">DAMNIT i hate it when I make a dumb mistake. Ill just get new bolts for all four, and Ill do it when I replace other thigns.
As a side topic how hard is it to change your Timing belt yourself?</TD></TR></TABLE>
well... no offence if you dont know the difference between inch lbs and ft lbs then changing the timing belt might be pretty hard.
On a SOHC motor its about a 1 hour job for timing belt/water pump tops.
I was just simply pointing out. If you take my advice or not is irrelevent. But if you ask any mechanic (which you were asking) if someone that doesnt know the difference between " lbs and ' lbs then they would recommend that they should not do serious maintenance to their car. Also, I mean it was pretty funny when you tried to prove that you were right and scanned in the torque specs. I mean, we all make mistakes, its just good to laugh about them. Seriously, dont take it personal, I've done lots of dumb things.
Anyway, just take your time and it is an easy thing to do.
Drain coolant, set motor to TDC Undo belts, remove valve cover, remove crank pulley, remove drivers side engine mount, remove timing belt cover, loosen timing belt tensioner, remove old timing belt, remove old pump, clean pump gasket surface, install new pump, install new belt, check TDC, adjust timing belt tensioner, reinstall all parts in reverse order.
That is it in a nutshell. If you feel comfortable doing all those things then you wont have a problem. Just remember, star pattern when you tighten the water pump and torque in steps for a more accurately torqued bolts. I would do 50in lbs then 105in lbs.
Take it with a grain of salt, im just some internet dude.
Modified by irev210 at 3:29 AM 6/27/2004
You know what i feel quite confident that you are incompetent. Common sense should have told you otherwise. Therefore for being a hater casue you made the mistake you get the boooooo and
oh and who cares about spelling at least his SOHC bolts didnt break!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KarbinFourteen »</TD></TR><TR><TD CLASS="quote">"spec are NOT 73 or 83....those bolts will snap at like 22!!!!!
go to honda...take valve cover off again....get 12mm deep socket...take old one out...put new one in..."
No your wrong book says 84-look below!
Wait what does that say, oh yeah 84!! Boo ya!</TD></TR></TABLE>
THOSE ARE INCH POUNDS NOT FOOT POUNDS>>.....so i was right.....84/12=less than 10!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! booo yaaaaaaaaaaaaaaaaaaa
yes i do know what i'm talking about!!!
I can't believe you even thought that those little nuts and bolts would go anywhere near 80 ft lbs for a torque spec. Thats too funny and stupid at the same time.
lol...... kinda funny he went out of his way and all too show us that he cant read
...inch-lbs, not ft-lbs
bck15
Nov 29, 2017 03:07 AM
