Need Help with car boggin
Old Jun 23, 2004 | 04:36 PM
BaNned's Avatar
Default Need Help with car boggin
I got a 90 civic si. The car bogs when i step on the gas from 1st-5th gear. I recently changed the distributor but not the spark plugs and the spark plug wires. Im thinking its either the fuel pump or the fuel filter. Suggestions???
Old Jun 23, 2004 | 05:25 PM
drussell4801's Avatar
Default Re: Need Help with car boggin (BaNned)
check timing.
Old Jun 23, 2004 | 07:13 PM
Redline130's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BaNned &raquo;</TD></TR><TR><TD CLASS="quote">I got a 90 civic si. The car bogs when i step on the gas from 1st-5th gear. I recently changed the distributor but not the spark plugs and the spark plug wires. Im thinking its either the fuel pump or the fuel filter. Suggestions???</TD></TR></TABLE>
I'm going to assume you mean accelerating through all 5 gears and not going from 1st to 5th. I would change the plugs, wires (if they are the originals especially), and the fuel filter. Also, check your timing like it was mentioned above.
Old Jun 24, 2004 | 12:43 AM
Los.'s Avatar
also going throught the same thing good idea for changing the dist. but i bet new wires and plugs could help and a new belt but see what happens that kinda of stuff isnt that pricey
Old Jun 24, 2004 | 09:43 AM
BaNned's Avatar
car runs fine when it cold starts in the morning, but bogs after 10 minutes of riding. It bogs in every gear from first through fifth gear. I check all the spark plugs and they seem fine. Im gonna buy a new fuel filter and use the fuel injector cleaner to see if that helps and Ill check the timing.. Anymore suggestions????
Old Jun 24, 2004 | 10:15 AM
Redline130's Avatar
Default Re: (BaNned)
Another thing to consider would be your O2 sensor.
Silver89crx
Dec 30, 2007 04:24 PM
dAilyDrIver5
19
Jun 4, 2007 05:15 PM
civicferio8381
Apr 6, 2005 06:20 AM
94ls
11
Jan 27, 2005 07:44 AM
hcivic99
Dec 23, 2004 08:44 AM
