milling a b16a head...yes i searched.
Old Jun 23, 2004 | 03:47 PM
efgarage's Avatar
Default milling a b16a head...yes i searched.
im planning on putting a b16 head in my ls teg but i want to mill the head first.
for a allmotor daily driven setup how much can i mill the head?
one other thing whats a common hp # for basic lsvtec's?
Old Jun 23, 2004 | 04:24 PM
Rocket's Avatar
Default Re: milling a b16a head...yes i searched. (300bones)
If you run big cams you'll have problems with the small intake valve reliefs on your LS pistons. Milling your head will make this problem worse.
Old Jun 23, 2004 | 04:33 PM
efgarage's Avatar
Default Re: milling a b16a head...yes i searched. (Rocket)
i was thinking of milling the head 20 thou and using itr cams,so is milling the head
worth doing on a daily driver with a simple setup?
Old Jun 23, 2004 | 06:09 PM
turbociv's Avatar
should be ok as long as you clay the motor and take out what you have to on the intake side of the piston. But i dont recommend for a motor that needs to last 100,000mi.
DTRcivic
10
Jun 26, 2004 09:33 AM
b16si
Jan 20, 2004 09:04 PM
corgiat
Sep 9, 2003 12:17 AM
SuPeR_MaN
12
Sep 14, 2002 06:19 PM
ridnmyhonda
Jun 2, 2002 09:40 PM
