Need help wiring techmeter???
Who in here knows how to wire the techmeter (RPM) on to the distributor… I have a 2000 prelude DOHC VTEC… please help…
I have a JDM Motor… and it’s an internal coil… There’s only one plug to the distributor because it’s a obd2 … anyone know how to wire it to the JDM Distributor…
Modified by yangja at 1:53 AM 6/24/2004
The only connection you have to make to the engine harness is to wire the tach signal wire(probably green) from the tach(assuming aftermarket)to the coil negative,on my 4th gen, the coil negative is blue, I think the wire is the same color on your car, but i'm not sure
91CivicHatchback
May 22, 2005 03:45 PM
tylek17
Jan 7, 2004 08:21 PM
H23vtecEG
Oct 14, 2003 05:02 PM
