Can't engage clutch - HELP!!!
Old Jun 23, 2004 | 02:18 PM
ATgrills.com's Avatar
Default Can't engage clutch,,, HELP!!!
Well i finally start the car after the 4 month build... starts fine.. fix all the little leaks and whatnot,, then I go put it in gear,,, but she wont go???
I turn off the car, now it goes into all the gears perfectly,,,
So my friend tells me the put a few washers at the end of the clucth step so that the clucth pushes further... did it and NO Difference
Ah right now im totally frustrated and fed up!
I have a dual diaphrame pressure plate with a type R disk and stick flywheel...
Im gonna take off the tranny tomo and see whats going on with the pressure plate,, im guessing thats the problem?
any other suggestion?
thanks
Tyler
Old Jan 7, 2005 | 07:16 AM
nomotorsol's Avatar
Default Re: Can't engage clutch,,, HELP!!! (ATgrills.com)
i am experiencing this same problem. i got the swap done, every leak was stopped, all was looking good. tried to put it in first gear....wouldn't go. it would go through all the gears like a champ when the car was off (obviously) but no such luck when stuff started spinning. what did you end up finding out? i'm taking my tranny off today to see what's up inside.
Old Jan 7, 2005 | 07:32 AM
RaVAGE00's Avatar
New User
Default Re: Can't engage clutch,,, HELP!!! (nomotorsol)
Having almost the same issue, however, sometimes the car will engage into first while the engine is on. Most times it will not....
Setup - R Tranny, JFD FD, TODA FW, Act PP, Kush-Loc clutch...
Car is in storage now, however, going to be pulling the tranny in the spring to see whats up.
Old Jan 7, 2005 | 11:07 AM
ITR#132's Avatar
If:
Engine Running-Wont go into any gear
Engine Off-Goes into all gears
Most likely a clutch problem. Try putting into 1st gear (engine off), start the engine and drive, if the car drives-its the clutch.
Old Jan 7, 2005 | 05:15 PM
EVILhatch's Avatar
same thing happened to me a while back and the pressure plate was the problem.
Old Jan 7, 2005 | 05:43 PM
43MA's Avatar
Default Re: (EVILhatch)
are you getting movement at the clutch fork?
Old Feb 2, 2005 | 07:33 PM
YaMaJeSty's Avatar
Default Re: (Steady)
wow, seems like a lot of people are having this problem. can anyone shed light on how to fix it?
Old Feb 2, 2005 | 07:38 PM
SlowReaction's Avatar
Default Re: (YaMaJeSty)
Have someone look at the slave as someone pumps the clutch to see if there any movement. If thats work fine then its probably the pressure plate.
Old Feb 2, 2005 | 08:20 PM
MOVE OVER's Avatar
Default Re: (SlowReaction)
i had the same problem when my clutch master cylinder went out- i got stuck at an intersection all of a sudden. try pumping it a few times quickly and then try getting it into gear.. that was my problem so i had an easy fix with my new master cylinder
Modified by KGsITR at 9:53 PM 2/2/2005
Old Feb 4, 2005 | 12:41 PM
YaMaJeSty's Avatar
Default Re: (KGsITR)
anyone know any quick fixes?
brian_ek
Transmission & Drivetrain
Mar 20, 2015 07:23 PM
S2KBAR
Dec 18, 2006 09:39 PM
ATgrills.com
Jul 8, 2004 06:48 AM
zad5
Jun 7, 2004 09:12 PM
zbower7
May 17, 2004 07:03 PM
