d16z6 cp piston ring gap..NEED HELP!!!
Old Jun 23, 2004 | 01:59 PM
D-booster's Avatar
Default d16z6 cp piston ring gap..NEED HELP!!!
OK I search and read some topic on this already, but some say gap the top ring smaller than the bottom ring, some say gap top and bottom ring the same, and others say gap top ring bigger and bottom smaller. SO..here's my build up that I have
cp psitons 75.5mm
Eagle rods
Arp studs
stock sleeves
I'm shooting for 300 whp with a good tune, so..if any of you guys have some experience with ring gaping or has done a similar buid up or know some formula to go by please help me out.
Old Jun 23, 2004 | 02:42 PM
USDM 4G VTEC's Avatar
Default Re: d16z6 cp piston ring gap..NEED HELP!!! (D-booster)
when i builded mines with the JE rings
i gapped them to what the card on the rings said
JE at least sent a paper with the ring gaps on them... top and bottom rings gaps are different, so be careful
Old Jun 23, 2004 | 02:47 PM
D-booster's Avatar
The problem is that CP doesn't come with recommended gap setttings. From what I've read CP leaves ring gap up to the engine builder.
Old Jun 23, 2004 | 05:30 PM
eddyboy's Avatar
Anyone help, our summit ring filer is in today and I wanted to start getting the rings gaped.
Thanks
Old Jun 23, 2004 | 07:54 PM
earl's Avatar
Default Re: d16z6 cp piston ring gap..NEED HELP!!! (eddyboy)
.017-8" upper
.020" middle
electric or hand crank?
Old Jun 23, 2004 | 08:19 PM
eddyboy's Avatar
Default Re: d16z6 cp piston ring gap..NEED HELP!!! (earl)
excuse my ignorance earl
what do you mean
Old Jun 24, 2004 | 12:01 PM
275Performance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddyboy &raquo;</TD></TR><TR><TD CLASS="quote">excuse my ignorance earl
what do you mean
electric or hand crank?</TD></TR></TABLE>
I believe Earl was asking did you get an electric power'd ring file or one of the hand power'd one you crank to file down.
Old Jun 24, 2004 | 12:56 PM
D-booster's Avatar
Default Re: d16z6 cp piston ring gap..NEED HELP!!! (275Performance)
He got the hand crank one, is one better than the other something?
Old Jun 24, 2004 | 05:23 PM
earl's Avatar
hand cranks are fine
Old Dec 29, 2005 | 09:23 AM
DelSolDon's Avatar
BFTD
i have wiseco 75.5mm low comp. (turbo) pistons. i have read that the gaps should be .017-.018 for the top ring and .020 for the second ring, but i see the same numbers for the larger bore b-series pistons. the sheet that came with the wiseco's says .004 per inch of bore which is what they are at right now w/o any filing done by me. my question is: are the smaller 75.5mm bore (D-series) pistons really supposed to be gapped at the same size as the larger 80+mm bore (B-series) pistons?
98Luder
17
Dec 18, 2012 02:07 AM
Wheelman-CZ
Feb 5, 2007 08:44 AM
yusoslo
Feb 9, 2004 03:13 PM
