cryogenically freezing for free?
Old Jun 23, 2004 | 11:40 AM
01h22lude's Avatar
Default cryogenically freezing for free?
hey everyone, if you have the chance to have all you shizzit cryo'd for free... would you? my buddy's dad has a 500lb tank in his garage (he works for air liquide) so it costs me nothing. this isnt a kit, this is the real thing, that costs like 400 bucks from a quality place. so any opinions?
Old Jun 23, 2004 | 11:41 AM
Rick Solis's Avatar
Default Re: cryogenically freezing for free? (UDubEric)
its free, why are you asking...
Old Jun 23, 2004 | 11:46 AM
xsiv's Avatar
Default Re: cryogenically freezing for free? (Rick Solis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rick Solis &raquo;</TD></TR><TR><TD CLASS="quote">its free, why are you asking...</TD></TR></TABLE>That's what I'm
f%&king thinking
Old Jun 23, 2004 | 07:06 PM
BryanPendleton's Avatar
Cryo treating's benefits are not so much strength, but primarily in fatique and wear resistance. So this will significantly increase the durability of your setup. Consider treating all moving parts than have metal-to-metal contact.
Old Jun 24, 2004 | 05:36 AM
slofu's Avatar
for free it's good, but keep in mind that your specs/clearances may change from it, so you might have to spend $ to have the parts properly machined back to spec. be sure to measure before you get less than that for which you pay: a heap of expensive, broken parts worth virtually nothing.
Old Jun 24, 2004 | 06:19 AM
david@didrace.com's Avatar
Just an example of how well it works. My brother works at an injection molding company and recently had a lot of the tooling for molds cryogenically frozen. The tooling used to last at maximum of a month before having to be replaced but now he's had the same tooling for over a year without a need to replace anything.
Modified by 10-94-55 at 3:45 PM 6/24/2004
Old Jun 24, 2004 | 06:31 AM
Daemione's Avatar
Default Re: cryogenically freezing for free? (10-94-55)
Isn't there more to it than just dumping the stuff in a vat & letting it sit? I thought the temperature was cycled on a specific schedule somehow . . . . .
Old Jun 24, 2004 | 08:10 AM
RPM's Avatar
RPM
Default Re: cryogenically freezing for free? (Daemione)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">Isn't there more to it than just dumping the stuff in a vat & letting it sit? I thought the temperature was cycled on a specific schedule somehow . . . . .</TD></TR></TABLE>
Yes there is. If you just dump your material into a vat you will freeze shock the material and you will get negative effects. The trick to cryo freezing is to slowly cool down the material over a certain time frame, this will give you the desired benefits of cryo-treating material.
Old Jun 24, 2004 | 11:57 AM
01h22lude's Avatar
Default Re: cryogenically freezing for free? (RPM)
no dumping! craziness i say! in this tank, its controlled by electronic timers and whatnot. the tank itself takes 500 lbs of material in one freeze. the electronics lower the temperature (using the nitrogen) to -300 at one degree a minute from room temp, hold it there a bit, then bring it back up in the same manner- one degree a minute- to room temp again. durability is definitely a plus for me, but all i will have apart is the block. so im thinking pistons and rods (2 sets, one for the future), rings, crank, bearings, miscellaneous parts like blots and whatnot. down the road ill do my head, but for now, it is alllll brand new anyway, so when i wear it out a bit, ill do more of a build and do it then. if its free, it me, and this process doesnt change the size or fotment at all, it is on a molecular level (however, im sure ill hear if im wrong on using this term, but its the best i can do!).
Old Jun 24, 2004 | 02:04 PM
I have worked with a local cryo facility for other reasons, but get this:
They have test results indicated that a cryo treated razor blade will last about 4 times as long as an untreated blade. This is based on colaboration with companies such as Gillette, etc. They know the benefit, but they (the razor companies) don't want to sell them, because then their products last too long then, and they want the product to remain a frequent consuming product.
Old Jun 24, 2004 | 02:09 PM
Rocket's Avatar
Default Re: cryogenically freezing for free? (BryanPendleton)
I just read RPM's post. Werd.
Old Jun 24, 2004 | 02:53 PM
Kendall's Avatar
Would it be possible (or logical) to cryo treat the block so that the sleeves would become stronger and more durable? If so, would this be a practical alternative to having the block sleeved?
Old Jun 24, 2004 | 08:50 PM
Joseph Davis's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Would it be possible (or logical) to cryo treat the block so that the sleeves would become stronger and more durable? If so, would this be a practical alternative to having the block sleeved?</TD></TR></TABLE>
Interesting line of thought.
I'd be worried about dissimilar metal expansion rates (sleeves versus block), and I dunno if the sleeves would be any stronger for it... VERY interesting question though.
Old Jun 24, 2004 | 08:54 PM
RenoRacing's Avatar
Default Re: (J. Davis)
Yeah, that's definately something that would take some planning and thought. I'm not sure how the different metals (steel and aluminum mainly) would take to contraction and expansion against eachother. Definately a cool idea though! I know the subaru guys would be jealous, i've heard of improvements by cryo treating their gears/trannys.
Old Jun 25, 2004 | 07:50 AM
01h22lude's Avatar
Default Re: (RenoRacing)
hey all, i have someone on ha.net who has some good advice. ill post a link there at the end of this, hope i dont get into trouble! hehehe, anyway, apparently i dont do things that are billet, forged, or multi-metallic, ie, the pistons, the bearings... i was advised NOT to do the block because i run the risk of the sleeves falling out, but if i were to do them separately, it might work, eh? ill be doing crank, rods, and cams, maybe something else. keep talking guys!
http://www.honda-acura.net/for...44485
Old Jun 26, 2004 | 11:37 AM
RPM's Avatar
RPM
Default Re: (UDubEric)
The best way to imagine Cryo-treating:
"Picture a busy mall with people walking around everywhere, some spots are more crowded than others. The people represent the molecules and the spaces in between them represent weekness in the metel. When the metal is slowly cooled you gather all those people and group them together as close as possible. When the metal is heated, imagine the people grouped together each taking one step outward away from each other, all of them together and in unison until they cover the mall end to end. Now all the molecules are evenly spaced, there are no weak spots, heat dissipates faster, etc. By Cryo-treating you create a more uniform molecular struture therefore creating stronger metal."
https://honda-tech.com/zerothread?id=600850
Get-InsuranceQuotes
Southern California
44
Apr 6, 2008 09:38 AM
Grumpy
Feb 18, 2008 02:11 PM
Propulsion
Northern California (Sales)
13
Aug 22, 2007 11:48 PM
Ausmith
Jun 18, 2007 05:38 PM
RCautoworks
Welding / Fabrication
31
Nov 7, 2004 06:00 AM
