AXLE PROBLEM!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?
Old Jun 23, 2004 | 11:24 AM
92hatchattack's Avatar
Default AXLE PROBLEM!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?
ok guys ... i just put a d16a6 into my brothers 90 dx crx.........
are the 1.5 axles diffrent for the 1.6 axles???? we had to replace the pasenger side axle cause it was fucked up ... the store had 2 diffrent numbers ./.. one for the 1.5 and one for the 1.6 ... they didnt have the 1.6 so i told my brother to just get the 1.5 ..... i thought they were all the same ...
anyway ... the axle/tranny is making a terriible grinding noise when u start to move .... not when its in nuetral or the clutch is depressed... but as soon as u move it grinds ...........
now the weird thing is we replaced the passenger side axle but i can swear that the griding is from the drive side!!!!
what do u guys think it is???? is it posible for the two diffrent trannys to have grinded down diffrently and the splines just arent gripping?????
Old Jun 23, 2004 | 11:28 AM
manson's Avatar
Default Re: AXLE PROBLEM!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!? (92hatchattack)
im not positive, but i would think they would be different. maybe they have different spline #s, but if they did it wouldn't slip in to easy.... or the lenths are different... i don't know exactly.
BUMP up for someone that needs some help.
Old Jun 23, 2004 | 11:34 AM
4drEF's Avatar
Keyboard Humorist
I looked up the part numbers on http://www.hondaautomotiveparts.com a long time ago and all the axles for 88~91 DX, LX... automatic, standard... sedan, CRX, hatchback... etc are all the same EXCEPT for the CRX hf and the Civic STD.
I guess you can double check it for yourself, but that's what I remember.
Old Jun 23, 2004 | 12:05 PM
Default Re: AXLE PROBLEM!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!? (4drEF)
thanks guys!!!! i was pretty sure they would be the same ..... hondas really not knows for changing **** up alot ya know.......
so what do u guys think the grinding couls be?? just diffrent wears and tears between the diffrent tranny and my stock axles?????????
im going to grab a new drive side axle and put it in tonight .... see if that does the trick.......
Old Jun 23, 2004 | 12:06 PM
haha .. ya know ..... go figure..... i get all the hard **** done ... the dpfi to mpfi conversion goes perfect, lol , and im stuck with a silly ******* axle problem .... lol ... i tell ya .......
RanCRX
Transmission & Drivetrain
Dec 28, 2009 03:03 PM
RanCRX
GYChris
Dec 4, 2008 05:58 AM
Bserieskiller
Feb 16, 2006 03:39 PM
poorman's type-r
Dec 3, 2005 03:45 PM
