Need help with my cars idle
Old Jun 23, 2004 | 11:21 AM
decipher_this's Avatar
Default Need help with my cars idle
Hey my car wont keep the idle at a constant rpm. It will vary from 1500 to 500 and will just start shaking. I know it should vary a little bit once it gets running but i doubt it should be this much. I ran some engine cleaner through it and changed out the spark plugs and wires but it didnt help. Any ideas? Thanks guys
Old Jun 23, 2004 | 01:01 PM
david90's Avatar
Default Re: Need help with my cars idle (decipher_this)
check your IAC
Old Jun 23, 2004 | 02:22 PM
Default Re: Need help with my cars idle (david90)
i took off my iac and cleaned it and everything and put it back on, I also changed out my PVC valve. Im still searching for ways to do it but i dont wanna try expensive stuff like the MAP Sensor untill I know there is no other choice. Thanks though, any other ideas?
not PVC i meant PCV its not a stupid pipe lol
Old Jun 24, 2004 | 08:11 AM
chansw's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by decipher_this &raquo;</TD></TR><TR><TD CLASS="quote">Hey my car wont keep the idle at a constant rpm. It will vary from 1500 to 500 and will just start shaking. I know it should vary a little bit once it gets running but i doubt it should be this much. I ran some engine cleaner through it and changed out the spark plugs and wires but it didnt help. Any ideas? Thanks guys</TD></TR></TABLE>
Is your car stock? I believe some mods can cause this to happen.
Old Jun 24, 2004 | 08:46 AM
david90's Avatar
changed your fuel filter lately? Your problem could a vacuum leak
oneprelude
Jun 30, 2008 06:22 AM
hai_tech
19
Mar 20, 2007 07:26 PM
AllMTRWH0R3
Aug 4, 2004 03:40 PM
jcivicsib20
Mar 13, 2003 08:42 AM
