AC compressor interchangeabity
Old Jun 23, 2004 | 10:19 AM
DavidR's Avatar
Default AC compressor interchangeabity
Does anyone know if I can bolt up a 96+ D series AC comperssor to a 95 civic D series? Is the mounting the same for the lines and to the block? Thanks.
Old Jun 23, 2004 | 10:34 AM
Built to Spill's Avatar
el diablo
Default Re: AC compressor interchangeabity (DavidR)
You wont be able to use the 96-00 a/c compressor. After 1994 compressors switched to R134 from the R12 systems. So you have to make sure that you get a compressor that uses the same kind of refrigerant you use in your car.
Old Jun 23, 2004 | 10:49 AM
DavidR's Avatar
Default Re: AC compressor interchangeabity (Built2Spill)
The freon type has no bearing on if it will fit and if the lines will bolt up or not. I have a 95 coupe, but need a new compressor, and since 96+ are so abundant....
Now, anyone got an answer for me?
Old Jun 23, 2004 | 10:54 AM
el diablo
I didnt see that your car was a 95. I was thinking you had a 92-94 civic...which if that was the case you could bolt it up but your freon type wouldnt match.
anyways...i think it does bolt up if you use a 92-95 bracket with it, the refrigerant lines could cause a problem though.
Old Jun 23, 2004 | 11:01 AM
DavidR's Avatar
I figure it will mount to the block, but I am not entirly sure on the lines. Someone has to know.
accordin 2 me
40
Jan 4, 2015 05:49 AM
notnilc20
Jun 16, 2012 10:34 PM
mikehawk
Jan 4, 2009 12:35 AM
fitbmx86
May 6, 2007 09:39 PM
