Picture Request - 4th gen Radius Rods
Old Jun 23, 2004 | 09:21 AM
PrecisionH23a's Avatar
Default Picture Request - 4th gen Radius Rods
Can anyone please share a picture from underneath a 4th gen showing both of the radius rods in relation to clearance to the motor and transmission? If you can, measurements would be nice.
The biggest help gets a free title change. Thanks
Old Jun 23, 2004 | 09:25 AM
del_parker's Avatar
Default Re: Picture Request - 4th gen Radius Rods (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone please share a picture from underneath a 4th gen showing both of the radius rods in relation to clearance to the motor and transmission? If you can, measurements would be nice.</TD></TR></TABLE>
i have a ton of pics of the underside of the car on my computer at the house, let me see if i can find a few that are useful.
PetroGuyX's Avatar
Tell me what that stuff is and i'd be glad to go out to my car and take a picture
Old Jun 23, 2004 | 09:29 AM
Default Re: (PetroGuyX)
I need measurements from the rods to the closest part of the engine/transmission. I have tons of pictures on my other computer, but as some of you know my main computer decided to stop working recently. If possible see if you could create a straight line from the 2 17mm bolts on the LCA to the actual radius rod spherical bushings and see if clearance is an issue.
I would like shots from directly below the motor as well as one from the side showing the clearance heights.
Thanks guys.
Old Jun 23, 2004 | 10:51 AM
del_parker's Avatar
here's two pictures from below the engine. the only pictures i have from the side are with the suspension disassembled.
in these two pics the car is on a lift with the suspension compressed normally.
i'll try to get the dimensions tonight after i get off work unless someone else has them.
Old Jun 23, 2004 | 02:54 PM
Behan's Avatar
Default Re: (PrecisionH23a)
i measured the clearances you asked for then i jacked up the car and took pics of where the measurements were takin at. so the numbers in the pics aren't accurate, as the car is jacked up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">I need measurements from the rods to the closest part of the engine/transmission. </TD></TR></TABLE>
Driver's side radius rod to oil pan = closet point is roughly 1.5 in
Passenger's side radius rod to the tranny = closet point is roughly 3.0 in directly above the rod.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">possible see if you could create a straight line from the 2 17mm bolts on the LCA to the actual radius rod spherical bushings and see if clearance is an issue.
i took a measurement from the beginning of the radius rod on the lca to the bushings and it was roughly 20 in. I don't see any clearance issues creating a straight line from the lca to the bushings ( on either side)
this pic is the passenger side just to give you an idea of how the measurement was done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">I would like shots from directly below the motor as well as one from the side showing the clearance heights.
i couldn't get one from directly below but del parker covered that any way. i did however take a measurement of the ground clearance at the lowest point on the radius rod (on both sides) and it was roughly 6.5 in. Heres a pic, ( the car isn't jacked up in this pic)
Thanks guys.</TD></TR></TABLE>
No problem.
if you need any other pics/measurements, i'm bored at work until about 12 or 1 am.
Old Jun 23, 2004 | 06:23 PM
es_squared's Avatar
Default Re: (Behan)
cool hair arm
Old Jun 23, 2004 | 06:24 PM
junbb1's Avatar
Default Re: (Behan)
No problem.
if you need any other pics/measurements, i'm bored at work until about 12 or 1 am. [/QUOTE]
damn steve is it a full moon. you got some teen wolf action going on on your arm
Old Jun 23, 2004 | 06:28 PM
Behan's Avatar
Default Re: (junbb1)
atleast my back doesn't look like that. i am a hairy ****, but its blond so that helps.
Radim
Dec 27, 2009 01:49 PM
twobit
Nov 15, 2005 08:23 AM
tylertx666
Jul 15, 2005 09:34 PM
turbo sol
Mar 12, 2003 05:32 PM
