Painting Oem Fog light housing??? How to???
Hey guys i just got some oem fog replacements i want to paint the housing black. How would you guys recomend i do this? What steps should i take?
Thanks guys
Thanks guys
Mine are painted with black BBQ paint. I keep it around for all misc black paint jobs, 1200degree = usefull everywhere.
I don't care much for asthetics, more about performance so I just roughed them up with sand paper, cleaned them off and then sprayed a thin spotty coat, let it get sticky then spray a wet coat. Avoid over spraying, it'll run.
Every 9months or so just.... Rinse/Sand/Repeat
I did mine with regular Fast dry trim paint from PEP Boys.Dries to a hard finish in like 5 min.It dried to like a satin finish which I left alone.Holds up pretty well,no scratchs yet.Good luck.
Try that new krylon paint for plastic http://www.krylon.com/main/pro...tails
It is called Krylon fusion.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI »</TD></TR><TR><TD CLASS="quote">Try that new krylon paint for plastic http://www.krylon.com/main/pro...tails
It is called Krylon fusion.....</TD></TR></TABLE>
I really wouldn't use this.We have it at Sherwin Williams.
And have got a bunch of complaints about it peeling after a couple of weeks.
Its up to you though.
sem trim paint.
It minght be a bit hard to get, its what body shops use.
It comes in a spray can, and for different makes.
There is ford, toyota, honda, ect.....
type_racerz
11
Dec 25, 2002 02:19 PM
