Anyone running CTR pistons in their ITR.
Old Nov 16, 2001 | 12:42 PM
blazin's Avatar
Default Anyone running CTR pistons in their ITR.
Can you safely run JDM CTR pistons in a B18C5 without detination and any valve clearance problems?
Old Nov 16, 2001 | 01:12 PM
IntegraT's Avatar
Default Re: Anyone running CTR pistons in their ITR. (blazin)
Yup
Old Nov 16, 2001 | 01:17 PM
MackSpeed-616's Avatar
yes
Old Nov 16, 2001 | 02:17 PM
fitzuni's Avatar
New User
Default Re: Anyone running CTR pistons in their ITR. (TurboR616)
what is the comp.with ctr piston on the itr?????
Old Nov 16, 2001 | 02:23 PM
Jackson's Avatar
Default Re: Anyone running CTR pistons in their ITR. (fitzuni)
11.6:1 ish. according to kaplan's site.
Old Nov 16, 2001 | 02:55 PM
WayneGro's Avatar
Default Re: Anyone running CTR pistons in their ITR. (Jackson)
More like 12:1:1
I would watch your *** running that high compression on pump gas. I am sure you would have to get a reprogrammed ECU or PowerFC to run it safely.
Old Nov 16, 2001 | 03:27 PM
hybrid_eg's Avatar
Default Re: Anyone running CTR pistons in their ITR. (WayneGro)
definately well in the 12's neighborhood from what i have heard you can run this safely with a FPR, i.e SX, Paxton, get yourself a FPR, and it should be fine.. crank up the FRP little more, and you might need to retard the timing.. getting an aftermarket ECU would be a plus but that can get costly.. if you are going to get aftermarket cams you might want to look into getting one to achieve their full potential. If i decide to build my motor i'm pretty sure i'm getting i'll be getting those pistons as well as a part of my build up.
Old Nov 16, 2001 | 06:05 PM
FAST94GSR's Avatar
New User
Default Re: Anyone running CTR pistons in their ITR. (hybrid_eg)
getting an aftermarket ecu is a must. putting ctr's in your car is a worth while thing to do.
GSR_hatch936
11
Jan 10, 2008 12:06 PM
danthemang3
Jul 16, 2007 02:54 PM
ceasar of mgineering
Jan 19, 2005 09:59 PM
toohott4handlin
Jan 19, 2004 05:21 PM
SystemGSR
Jan 9, 2002 04:06 AM
