possible to put a 1990 Si motor into my 92 EG cx?
I can get a motor and ecu from a 1990 crx si.....
for $150 with 80k miles.
question, will this bolt up to the oem 92 cx tranny and chassis?
reason being I have a 92 cx with 70 hp, and if I can upgrade for $150 in the time while I save up for an ITR/CTR swap.. then I will do it.
thanks guys.
Owen
thanks guys.
Owen
three things need to be done...change the driver side mount (on the block to the 92-5 style), change to the 92+ thermostat housing, reuse your old 92 injectors, distributor, ...plug your 92 harness up....
as far as tranny, sure it bolt up with out a problem...you can reuse your old ecu, but DX (p06) is recommended over the CX which really sucks...
smog legal
lucky us I know...
Why?...
If I can get MUCH better performance than the cx motor for only $150 and some hours of hard work, then it is worth it. the 70 hp motor is KILLING ME! its so sad, really, I actually I drove it 5 1/2 hours to Killington for a day of snowboarding last monday with some friends, it was sloooooooow on those Vermont hills.
three things need to be done...change the driver side mount (on the block to the 92-5 style), change to the 92+ thermostat housing, reuse your old 92 injectors, distributor, ...plug your 92 harness up.... as far as tranny, sure it bolt up with out a problem...you can reuse your old ecu, but DX (p06) is recommended over the CX which really sucks...
man, I love this site!
[Modified by owen_the_soyboy, 8:51 AM 11/17/2001]
******* **** man he just told you why he wanted to do that swap.
READ the post BEFORE you play high-and-mighty dude.
Jeez....
Jeez....
hahahaaaaaa, not in NY state, we are free from smog checks and swap laws.
lucky us I know...
lucky us I know...
right now...i am in the process of passing my JDM b16a at a state ref
hells yeah were lucky, hope it wont change any time soon too!
hey good luck with your passing the state regulations!
HELLAnorcal
Mar 23, 2006 01:44 PM
