JDM Integra Headlight/Fog Light Wiring
Old Jun 22, 2004 | 11:13 PM
jlehonda1's Avatar
Default JDM Integra Headlight/Fog Light Wiring
I bought pretty much everything for the JDM integra conversion. However it seems as everyone has told me...its rare to get the JDM integra fog light relay and wiring, how would I do a DIY project to get my fog lights working? Also does anyone know how to wire up the JDM integra headlights? pics would be greatly appreciated!
Old May 6, 2012 | 02:34 AM
dc_jdm_dreams's Avatar
Default Re: JDM Integra Headlight/Fog Light Wiring
I too would greatly enjoy any info on how to wire up my jdm fog lights.
Old May 6, 2012 | 10:31 AM
fcm's Avatar
fcm
Old Fart
Any SPST or SPDT relay will work for the fogs, $5 or less at any car parts store.
How they are wired will depend on how/when you want them to light up.
What year is the Integra?
The head light wiring should be the same although the bulb sockets will most likely be diff. yo you will need to swap them out. 94
Old May 8, 2012 | 06:50 PM
well I wired up my JDM headlights about a week ago. for the side markers i used the exact same 194 harness that it use for the turn signal/sidrmaker lamp that inside the USDM front bumper. I just had to lengthen the wires for them and then ran them inside the channels on the inside of the fenders. I will prob be changing this cause they don't blink they just stay on. I was thinking I can splice the power wired from the big blinker socket.
For the blinkers on the JDM front headlights I used the existing blinker three wire socket and bulb that is used on the USDM front bumper lights. Some will say that the socket does not fit inside the JDM headlights but they are right but you just have to take a little bit of material off of one of the JDM housing prong patterns and then replace the rubber grommet on the socket with a regular oring. Do this and they will fit quite snug but it works and it legal the blinker stays on when the lights are on and blinks when slected. as oppose to the JDM way which the blinker only comes on when the blinker is selected.
As for the headlights I have the JDM black NON Hid headlight housing. I choose this because of the ability to hid an aftermakert Hid kit. It looks stock if you use a 5000k HID kit. But the sockets are the same USDM/JDM and no modification is needed.
For the high beams the JDM non HID housing has a redish brown connecter. with this connector you will have the power wires for the high beams, city/daytime running lights,fog lights. All these share the same ground
I have yet to figure out how i am going to wire up my fog lights. But i have a remote idea of what do. But the way i want to do it will only work for my application because i am using an HID replay harness.
Old May 8, 2012 | 11:47 PM
Its all about what you want to blink/light up/ stay lit. keep in mind that the jdm style lighting and wireing is illegal in the US. JDM style is city lights on all time, corners only blink with turn signal selected, side markers on and blink when selected, fog lights on when selected with button and when headlights are on.
Old May 9, 2012 | 06:20 AM
90efb16's Avatar
There is a lot of write ups on this here's a good one imo
https://honda-tech.com/forums/lighting-107/how-jdm-itr-hid-headlight-fog-light-wiring-2195061/
Old May 9, 2012 | 07:52 AM
rsongt3's's Avatar
luckly i biought my jdm front integra with all the wireing done.
HONDRETTI
Aug 28, 2013 11:00 AM
ITR32
Aug 1, 2007 11:12 AM
SiHatchTurbo
Mar 31, 2006 08:12 AM
