Tubular vs. Semi tubular dyno
Old Jun 22, 2004 | 09:59 PM
JM Performance's Avatar
Default Tubular vs. Semi tubular dyno
found this on http://www.fab-forum.com thanks to ComposiMo.
http://www.fab-forum.com/forum...&PN=1
You mean this:
Versus this:
If so, here is the difference (blue line being the my manifold (with the longer/bent runners), and the red line being the 'straight runner' manifold) :
looks like tubular make a nice difference in midrange....probably due to much quicker spool up
Old Jun 22, 2004 | 10:16 PM
BoostedJeff's Avatar
Default Re: Tubular vs. Semi tubular dyno (00SilverLS)
45 lb/tq from a manifold
Old Jun 22, 2004 | 10:22 PM
Default Re: Tubular vs. Semi tubular dyno (JDMHatch4Me)
seeing your write that makes me cringe at waiting for the first idiot to yell "BS"
Old Jun 22, 2004 | 10:30 PM
Boltz's Avatar
funny how even though there was a 2000rpm difference in the maximum rpm of each dyno run, it some how managed to make the exact same hp to the tenth.
none the less nice numbers.
Old Jun 22, 2004 | 10:59 PM
paulzy's Avatar
what are the small blue lines towards teh end of the red lines?
Old Jun 22, 2004 | 11:47 PM
Nid Styles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00SilverLS &raquo;</TD></TR><TR><TD CLASS="quote">seeing your write that makes me cringe at waiting for the first idiot to yell "BS" </TD></TR></TABLE>
BS!
Sorry, didn't want to disappoint anyone, so I got it over with.
Old Jun 23, 2004 | 04:19 AM
RacerXI's Avatar
Default Re: Tubular vs. Semi tubular dyno (Nid Styles)
If i'm not mistaken , that is titan motorsports car. Either way, the difference is quite an eye opener.
Old Jun 23, 2004 | 04:52 AM
dennis's Avatar
nice attempt, but they're not even the same engine. How do we know the 45lbs didn't come from the modded valve cover?
Old Jun 23, 2004 | 07:02 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: Tubular vs. Semi tubular dyno (dennis)
What was the same and what was different between the two engines? Every detail please.
Old Jun 23, 2004 | 07:12 AM
Default Re: Tubular vs. Semi tubular dyno (tjbizzo)
from what was told and what it looks like only the manifold was changed.
Old Jun 23, 2004 | 07:22 AM
B18C1CYA's Avatar
well i see that it has a bigger wastegate, some thing just dosnt add up here
Old Jun 23, 2004 | 07:24 AM
dennis's Avatar
Default Re: Tubular vs. Semi tubular dyno (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">well i see that it has a bigger wastegate, some thing just dosnt add up here </TD></TR></TABLE> - yeah, noticed that too
Old Jun 23, 2004 | 07:27 AM
B18C1CYA's Avatar
must be running more boost to because of the extra vents in the valve cover we are not being told the full story on this one
Old Jun 23, 2004 | 07:58 AM
twkdCD595's Avatar
from the looks of the picture it is the same car/ motor in both pics... the extra breathers in the valve cover, different wastgate, and lack of information make it hard to believe it there was a good controled testing situation here.
though to the manifold... it makes great power obviously.
Old Jun 23, 2004 | 08:04 AM
Pworld's Avatar
From: somewhere in INGLEWOOD chillin in tha hood, CA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">must be running more boost to because of the extra vents in the valve cover we are not being told the full story on this one </TD></TR></TABLE>
is that what those are for??
learn something new everyday.
Old Jun 23, 2004 | 08:05 AM
Suprdave's Avatar
Default Re: Tubular vs. Semi tubular dyno (twkdCD595)
I remember ALONG time ago...like 4 years ago, I was talking to Full-Race Geoff on the Hybrid board about the Kooks Manifold he was using. Basically what he said was "It makes 50ft lbs, but you hafta reweld it every couple weeks." So that kinda goes along with that Dyno Graph is showing...althought that graph is weird as hell.
Old Jun 23, 2004 | 10:42 AM
SiRkid's Avatar
there is no doubt it makes a difference..but id say more so in that power range then down in the 300 whp range.
Old Jun 23, 2004 | 03:06 PM
ComposiMo's Avatar
The full story, is that the car in question had the SFP manifold on it with everything you see in the picture with the new manifold on it... i only showed a picture of the SFP manifold on the old motor they had in the car in that post because thats the only picture i had... i didn't have a good picture of the SFP manifold as-installed when they did the motor upgrade, which also was when they added the vent system on the valve cover, and the upgraded WG... but those items were on the car with the SFP manifold when the original dyno graph was done. The only differences on the motor between the two dyno runs is the new manifold, new downpipe (which was almost identical to the old one), and the new WG positioning and dumptube.
As for everything else, if you're looking for specs on the rest of the car, or verification of the dyno results, talk to Willis or TitanMotorsports.com (James) on here
Old Jun 23, 2004 | 03:47 PM
Full-Race Geoff's Avatar
this reminds me of a quote i once heard
"new ideas are at first dismissed... eventually they are regarded as hearsey ... afterwards, they are regarded as obvious"
Old Jun 23, 2004 | 04:07 PM
st00pid's Avatar
Default Re: Tubular vs. Semi tubular dyno (Full-Race Geoff)
I dismiss the quote. .. for now.
Old Jun 23, 2004 | 06:55 PM
c jackson's Avatar
threes
Default Re: Tubular vs. Semi tubular dyno (st00pid)
i heard about that quote.
Old Jun 23, 2004 | 07:04 PM
Default Re: Tubular vs. Semi tubular dyno (c jackson)
we will be doing our own test, using the same turbo, the same downpipe, the same wastegate, EVERYTHING. only change is manifold. we made a manifold special for this test.
boosted hybrid will be doing the testing.
Old Jun 23, 2004 | 07:06 PM
SiRkid's Avatar
Dont you need to retune for the new mani aswell?
btw...boosted car haulssssssssssssssssssss geoff... if only i could get the FR kit with t3/t67
Old Jul 1, 2004 | 10:46 PM
this test was a lie, we have conducted our own test, in an unbiased private location COMPLETELY VIDEOED and i can quite clearly say our results were VERY different from the titan results.
Old Jul 1, 2004 | 10:55 PM
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">this test was a lie, we have conducted our own test, in an unbiased private location COMPLETELY VIDEOED and i can quite clearly say our results were VERY different from the titan results.</TD></TR></TABLE>
where are these test results??
I already know full race can make power
