my crx fmic
Old Jun 22, 2004 | 09:24 PM
c0nspire's Avatar
Default my crx fmic
me and my dad designed endtanks and everything for my crx. the intercooler was designed to fit under the stock bumper skin without removing the bumper and it uses the holes that the airconditioning uses. also since its a 91 dx crx it has the full radiator, not the half sized one.
6 inches tall, 33 wide and 3 inches deep. 2.5" tube.
need to size up for the tabs and have them welded on.
we actually made a carboard version and then a wood version after to make sure it would fit under properly.
and the car
http://www.lowpolycg.com/project/
Old Jun 22, 2004 | 10:38 PM
Blaze45's Avatar
Brrraaaap!
Default Re: my crx fmic (c0nspire)
Wow, that looks really nice. How much pressure loss does it have and how efficent is it?
Blaze
Old Jun 22, 2004 | 11:08 PM
Los.'s Avatar
were did u get the intercooler fabed? or did u and your dad actually make the whole thing?
Old Jun 22, 2004 | 11:14 PM
c0nspire's Avatar
Default Re: my crx fmic (crxkid88Sir)
im not sure on the numbers, ill ask my dad in the morning.
we got the core from kinetic motorsport in langely BC and we drew up, cut and bent the end tanks ourselves. we would have welded them but we do not have a welder than can weld aluminum, only steel. the company that welded it was also in langley, just across the street
Old Jun 23, 2004 | 03:53 AM
crx_88_si's Avatar
is it on the car yet? take some photos of under the bumper where it goes.
Old Jun 23, 2004 | 04:19 AM
USDM 4G VTEC's Avatar
Just showing off
final product
Old Jun 23, 2004 | 04:45 AM
Curtis2kul's Avatar
Default Re: my crx fmic (USDM 4G VTEC)
I want one !!!!
Old Jun 23, 2004 | 05:15 AM
WhatThaFrig's Avatar
Default Re: my crx fmic (Curtis2kul)
sweet! Good work.
Old Jun 23, 2004 | 05:11 PM
c0nspire's Avatar
Default Re: (crx_88_si)
Old Jun 23, 2004 | 05:19 PM
Hawkze_2.3's Avatar
Default Re: (c0nspire)
Man, that looks awesome...How much piping do you think will save with that setup?
crxguy05sir's Avatar
nice guys i like what are the measurements for the both of yours
Old Jun 23, 2004 | 05:26 PM
c0nspire's Avatar
Default Re: (crxguy05sir)
not quiet sure on the piping issue, i wont have to run out and around. probably not a WHOLE lot, but anything we can save would be worth it.
whole ic:
Core:
6 inches tall, 24 wide and 3 inches deep.
therefor each endtank is 4.5 inches wide
Modified by c0nspire at 2:42 AM 6/24/2004
Old Jun 23, 2004 | 07:11 PM
c jackson's Avatar
threes
looks awesome!
Old Jun 23, 2004 | 08:02 PM
cloud806's Avatar
daym that looks hella nice
Old Jun 23, 2004 | 08:13 PM
Steemo's Avatar
Default Re: my crx fmic (cloud806)
that looks really clean that should be a fun car. let us know how much power it makes when you get the numbers.
Old Jun 23, 2004 | 08:15 PM
SouLaQuaRiuS's Avatar
your intercooler looks perfect in the bumper
Old Jun 23, 2004 | 08:38 PM
Full Race A6's Avatar
Default Re: my crx fmic (SouLaQuaRiuS)
What motor will you be boosting?
Old Jun 23, 2004 | 09:54 PM
c0nspire's Avatar
Default Re: my crx fmic (W O T)
jdm sohc zc (z6)
endyn rollerwave pistons
Bore - 75.5mm
Stroke - 90mm
oversized endyn valves
Eagle H beam rods
modified oil pump
adjustable cam gear
cam shaft and valve springs from endyn
im prolly forgetting stuff *yawn* its late and i need to work so i can have funds for this project.
Old Jun 23, 2004 | 10:41 PM
justinh595's Avatar
Isn't it great you do all that work then a big *** truck going the opposite direction kicks up a rock and you get a big dent.
Put something over it if you can. The bling of a shiny *** intercooler draws the wrong attention anyway. thieves
Old Jun 23, 2004 | 11:24 PM
Jonathan_ED3's Avatar
c0nspire, wow...now THAT is a perfect fit!
Put a mesh grill or something in there, and paint the intercooler black. Definitely not something I'd be showing off! All that hard work can go down the drain quickly when it catches the eye of the wrong guy.
I like things to be stealth!
Old Jun 24, 2004 | 06:14 AM
c0nspire's Avatar
Default Re: (Jonathan_EH)
actually i was planning on painting it black, gunna try to keep the car as stock looking as possible, try to hide it in there :D
Old Jun 24, 2004 | 01:25 PM
pntballfreak's Avatar
Wow...
VERY nice.
Old Jun 24, 2004 | 01:43 PM
5litereater's Avatar
Default Re: (pntballfreak)
welds look emaculate. really good job
jdmcd5accord
Mar 22, 2007 10:43 PM
jaydmcrx
Feb 11, 2005 11:21 AM
ExplicitSpeed
11
Jan 25, 2005 03:24 PM
See Are X
Jan 28, 2003 05:30 PM
