cranking but no start.... zero fuel pressure.
Old Jun 22, 2004 | 08:37 PM
sol2nr's Avatar
Default cranking but no start.... zero fuel pressure.
This morning I moved my car out of the driveway so my mom could leave for work. I went in house for 4 hours, and came back out to leave for work. Started the car no problem, reversed 5 feet and it stalls out. Zero fuel pressure. & zero oil pressure, i think. When i turn the key to the accessory position, no priming of fuel pump. where should i start looking for the problem. i looked quickly for fuses, but didn't find a specific one. i'm going to check my helms tomorrow morning, but just wanted to hear some quick suggestions as what to check so i don't go crazy.
For the record, i installed a brand new Walbro 255HP fuel pump this past january and everything was working fine up til this afternoon. Last night i repeatedly used the nitrous, but drove the car home running regularly. Other fuel system components are Golden Eagle fuel rail, Aeromotive FPR, and i have both digital and mechanical fuel pressure gauges tapped off of the fuel rail.
thanks for any info.
-ROB
Old Jun 22, 2004 | 09:18 PM
v4lu3s's Avatar
RTFM
check main relay...
Old Jun 22, 2004 | 09:48 PM
bseriesbenny's Avatar
also u might want to check your igniter if the car was running like poo before it dies. if not check the main relay and fuses
Old Jun 22, 2004 | 09:51 PM
sol2nr's Avatar
Default Re: (bseriesbenny)
how exactly do i check the main relay...i'm not good with electronics. check what? to see if it has power? volt meter it?
oh yeah....car ran excellent until it instantly cut out.
since there wasn't an in-between shitty running period, i would assume its electronic.
is there an actual main relay fuse, like in the fuse box?
Old Jun 22, 2004 | 09:53 PM
BatuKing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bseriesbenny &raquo;</TD></TR><TR><TD CLASS="quote">also u might want to check your igniter if the car was running like poo before it dies. </TD></TR></TABLE>
not the problem his fuel is not priming so the ignition is not sending a signal or his fuel relay (which is part of the PGMFI relay) is not working
Old Jun 23, 2004 | 07:47 AM
sol2nr's Avatar
Default Re: (BatuKing)
how can i check if the ignition is not sending a signal?
i'd like to check that before i replace the main relay, (which is the fuel relay you're referring to right?)
Old Jun 23, 2004 | 07:55 AM
Gra's Avatar
Gra
Default Re: (sol2nr)
http://www.markl.f9.co.uk/howt...y.htm
Old Jun 23, 2004 | 08:32 AM
sol2nr's Avatar
Default Re: (Graham D)
thanks, i printed that article out late last night...and was about to read it.
good to add the link to this thread for other people.
Old Jun 23, 2004 | 11:49 AM
sol2nr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2nr &raquo;</TD></TR><TR><TD CLASS="quote">how can i check if the ignition is not sending a signal?
i'd like to check that before i replace the main relay, (which is the fuel relay you're referring to right?)</TD></TR></TABLE>
Old Jun 23, 2004 | 05:05 PM
v4lu3s's Avatar
RTFM
typically if youa re not getting your fuel pump to prime and the engien does crank over then the problem is the main relay which is typically straight up inside teh dash above teh fuse box, with a gray casing and a brown plug. i have had to replace 2-3 of them recently for people for the exact symptoms you are having though they were able to at least crank the car over (nto sure if you can or not). ]
anyway that artile linked to above is great...
Old Jun 23, 2004 | 05:45 PM
Jimmy's Avatar
Global Moderator
Heres my PGM-FI main relay write up:
https://honda-tech.com/zerothre...00860
Also to get your car started for now...reach down there and tap/hit on the relay.
Old Jun 23, 2004 | 06:36 PM
sol2nr's Avatar
Default Re: (Jimmy)
thanks for the info.
I checked the fuel pump, and the main relay. then i checked the ecu fuse and that was it. kinda weird b/c i've pulled that fuse in the past as a security measure, and i thought i remembered it not allowing the engine to crank. but this time the engine cranked and had spark, just no fuel or oil pressure.
o well...nice and cheap fix!
Modified by sol2nr at 12:09 AM 6/24/2004
caspersrevenge1
Aug 8, 2013 12:59 PM
hlau2o9
Dec 11, 2008 09:19 PM
skUnK2jdm
Jan 30, 2007 03:55 PM
90TegraB18C
Aug 27, 2006 05:32 PM
ricecooker415
Aug 14, 2005 08:00 AM
