What AEM intake is this?
22-401 is the PN highlighted on the manual. I found it on AEM's site but there's nothing said about the holes.
Honda Civic 1996-00 EX 22-401
Honda Civic 1992-95 DX/EX/LX/Si 22-401
Honda Del Sol 1993-95 SOHC 22-401
Honda Del Sol 1994-97 DOHC 22-401
yeah thats what i found as for the holes did it come with any solid rubber plugs because you should only need one hole (if your using it for a 92-95)
There's nothing in the plastic bag. There's two holes plus the nipple for the PCV hose. Guess I'll have to call AEM in the morning so they can send me some plugs or whatever...
my 98 civic AEM short ram has 1 hole for the MAF sensor and u put this little rubber piece in there and then the other bump thingy to put the breather on. Not sure what the other hole is for.
AEM went cheap and made the intakes for all EG and EK and another one I forget.. I think DA so if you look there is 3 CARB numbers on it and check the application chart on their site to the part number.. you will see they are similar.. so depending on the car you have you use the approprate hole
5Hondas
Feb 3, 2006 07:55 AM
thats funny!!
