IM Question for 94 LS
Old Jun 22, 2004 | 03:57 PM
pearlteg's Avatar
Default IM Question for 94 LS
which IM should i go for if am going NA? i was thinking skunk2? any opinions?
Old Jun 22, 2004 | 03:59 PM
tegasaurus's Avatar
Default Re: IM Question for 94 LS (pearlteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearlteg &raquo;</TD></TR><TR><TD CLASS="quote">which IM should i go for if am going NA? i was thinking skunk2? any opinions?</TD></TR></TABLE>
skunk2
Old Jun 22, 2004 | 04:23 PM
pearlteg's Avatar
Default Re: IM Question for 94 LS (tegasaurus)
any reason why skunk2 is better then the other?
Old Jun 22, 2004 | 04:31 PM
tegasaurus's Avatar
well you could use a type R but you'd have to drill a couple new holes and its the exact same thing as the skunk2.
you could use the edlebrock, but i'd only use that if oyu have a turbocharger because its made for 7500+ rpm or fi use. You could use a sheet metal intake but that costs much more $ and will have the same results as the edelbrock.
skunk2 is the only economical choice cost vs work/results wise.
The HamsterBall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearlteg &raquo;</TD></TR><TR><TD CLASS="quote">any reason why skunk2 is better then the other?</TD></TR></TABLE>
well it's either skunk2, ITR, Internal Throttle Bodies, or just porting/flowing your stock intake manifold.
(BTW, skunk2 IM is basically a replica of the type R IM)
Old Jun 22, 2004 | 04:41 PM
tegasaurus's Avatar
Default Re: IM Question for 94 LS (The HamsterBall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The HamsterBall &raquo;</TD></TR><TR><TD CLASS="quote">
(BTW, skunk2 IM is basically a replica of the type R IM)</TD></TR></TABLE>
what are internal throttle bodies?
and a skunk2 im IS a replica of the itr.
Old Jun 22, 2004 | 04:45 PM
pearlteg's Avatar
ok thanks for the opinions, cus am going with the itr 4-1 header. hopefully i get some good power gains
jeffk182
16
Jan 26, 2005 07:17 PM
NathanMorris
Dec 20, 2004 10:03 PM
juicedh22
Jun 17, 2004 08:14 PM
rough_draft
May 2, 2004 08:51 PM
Integra21
Dec 4, 2003 03:03 PM
