Help with OBD
Old Jun 22, 2004 | 03:09 PM
integmester's Avatar
Default Help with OBD
Will a OBD I ECU work with OBD II motor? Starter doesn't crank and I was wondering if the OBD I ECU would cause it not to crank. Any help is great.
Old Jun 23, 2004 | 04:54 AM
JimBlake's Avatar
Default Re: Help with OBD (integmester)
The ECU shouldn't be part of the starter circuit at all. What car/engine/ECU?
Old Jun 23, 2004 | 09:08 AM
kimchiboi629's Avatar
yes the ecu have effect on the car to start. I there is a pin on the ecu that is for the starter called a starter signal. The connector that connected to the ecu might be in different slots. So you might have to swap the wires in the connector around. But first you should get a pin voltage chart layout of the 2 ecu what see what each pins are for. You could get this from mitchell on demand.
Old Jun 23, 2004 | 11:03 AM
Joseph Davis's Avatar
Default Re: Help with OBD (kimchiboi629)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kimchiboi629 &raquo;</TD></TR><TR><TD CLASS="quote">yes the ecu have effect on the car to start. I there is a pin on the ecu that is for the starter called a starter signal. </TD></TR></TABLE>
What pin would this be on OBD1?
Old Jun 23, 2004 | 11:18 AM
JimBlake's Avatar
Default Re: Help with OBD (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">What pin would this be on OBD1?</TD></TR></TABLE>That would be B9. But I thought that was a signal telling the ECU that the starter was cranking. NOT an opportunity for the ECU to interlock the starter.
efb16
Aug 12, 2005 08:36 AM
lude97dude
Jul 23, 2003 11:54 PM
