crx wont start ls swap and obd1 swap
Old Jun 22, 2004 | 02:52 PM
cd1fidy's Avatar
Default crx wont start ls swap and obd1 swap
have everything stalled just wont start ecu throws 1 code engine coolant temp
sensor. Not really that big of a deal the car should atleast start. I have
compression, spark, and theres fuel pressure in the fuel rail. timing is right, my
only guess is that injestors arent recieving a signal, they came out of a working
car so they should work. any ideas?
Old Jun 23, 2004 | 08:21 AM
cd1fidy's Avatar
Default Re: crx wont start ls swap and obd1 swap (cd1fidy)
anyone or does nobody know
Old Jun 23, 2004 | 09:44 AM
cd1fidy's Avatar
glad this is the place to come for awnsers
Old Jun 24, 2004 | 03:36 AM
Jeff C's Avatar
Was it a dpi car?
Old Jun 24, 2004 | 08:50 AM
QUiKSR20's Avatar
Is this a CRX Si / HF or a DPFI Car? What engine are you running and with what harness? If your using the Si Harness with resistor box with OBD 1 you need OBD O ( NON OBD ) injectors. That could be your problem. The Si Harness with the resistor box needs the right injectors.
Old Jun 24, 2004 | 02:58 PM
cd1fidy's Avatar
Default Re: crx wont start ls swap and obd1 swap (QUiKSR20)
88 crx si, with resistor pack running dsm 450 injectors with resitor pack, pr4 wiring harness, blownhatch's obd0-obd1 conversion harness, 94 ls ecu with uberdata chipped for boost.
Old Jun 25, 2004 | 07:53 AM
QUiKSR20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cd1fidy &raquo;</TD></TR><TR><TD CLASS="quote">88 crx si, with resistor pack running dsm 450 injectors with resitor pack, pr4 wiring harness, blownhatch's obd0-obd1 conversion harness, 94 ls ecu with uberdata chipped for boost.</TD></TR></TABLE>
Hmm Im not sure. Havent messed around with that combo. Maybe someone else can chime in with better ideas.. Good Luck with it.
Old Jun 29, 2004 | 03:39 AM
Jeff C's Avatar
How are you controling those 450's...AFC, or is that done by the Uberdata?
93hatchy08
Aug 22, 2009 07:12 AM
crazydude107
Aug 24, 2008 02:43 AM
dohccrxsi
10
Aug 18, 2008 10:36 PM
gogosobewfew
Oct 18, 2005 10:10 PM
integraracing91
11
Aug 15, 2004 03:58 PM
