crankpully help asap (long)
I took my car a 91 hatch, to a guy to fix it and get it running
He changed the timingbelt for me but called me and said i had the wrong crankpulley on it so he had to change it out
I have a 96 d16y7 in my hatch and he got a new pully from his friend and installed it so i go to pick up my car after he calls me and i get their and he says its throwing a code 3 map
So im like i will just drive it home slow.Well its sputtering like crazy and as im driving it home at around 40 or so and all of a sudden boom something flies off
and my batterie light comes on so i pull over and look and my crankpully fell off
like the bolt wasent tightened.
So i drive home and look at it in the morning and i had the stock pully in the car
So i put it on tighten it by hand as tight as i can get it
Start the car up after fixing the map and the crank pulley is making this loud noise and I look at it and its shaking like its not tight enough
I dont have a compressor all i have are hand tools
Could i have messed something up driving it about 20 miles with the pully off
please help me
Thanks
please help me
Thanks
I think that guy might have messed it up. You shouldent just need a new crank pulley. Also there are other things that can make it shake like that. I really think he might have messed up you motor, not a crank pulley. Also why dont you have the cover on it that might be part of your problem. Good luck
The one on there is not right. Take it off and put the other one on. That can throw your crank off balance. I have never seen that type of crank pulley. (on a honda at least) I dont know what that guy was thinking.
the little chuck is calld a woodruff key if its not on there you will have serious problems like the plully flapping around an spinnig on the crank snout
I belive you can get those keys at a local hardware store. just make sure you dont get the half round kind. Also that may be the cause for the first one falling off the car. Deffenatly get ahold of the guy who did the job.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MENACE »</TD></TR><TR><TD CLASS="quote">I belive you can get those keys at a local hardware store. just make sure you dont get the half round kind. Also that may be the cause for the first one falling off the car. </TD></TR></TABLE>
The lack of a woodruff key would only allow the pulley to spin freely on the snout of the crankshaft. The crank pulley is kept on by the HUGE shouldered washer on the crank pulley bolt. All he needs is a woodruff key.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC »</TD></TR><TR><TD CLASS="quote">
The lack of a woodruff key would only allow the pulley to spin freely on the snout of the crankshaft. The crank pulley is kept on by the HUGE shouldered washer on the crank pulley bolt. All he needs is a woodruff key.</TD></TR></TABLE>
Yes but the motor Spins Counter clockwise so it should tighten the bolt. If the Key was never there. the friction from trying to spin the altenator would case the pully to spin slower on the crank. Thus rubbing the bolt causing it to spin off.
i see what you are saying about that key because if you look at the pully you can see it striped the inside.
I have anther pully that looks just like it but the teeth are still inside it
The other one i have
the one i used
the one i used
It should work just fine. But make sure you match them up and grab that Woodruff Key. Also Good luck trying to pull one off i hope the bolts not a bitch like there know to be.
O he has the y7 I was thinkin B7 for some reason. More than likly the Alt belt will be bigger and wont fit the Crankshaft pully. But im also sure its a different diameter on the d16's. If nothing more you can atleast get the Woodruff key there. Just put it in youre pocket.
see the alterntor belt i had gave to the guy to fix my car was to short to use with the stock pulley so thats why he got another pully
So today when i went to put the stock pully back on the belt didnt fit so i went to the hardware store and got a longer belt and it fit except for the problem i am having since i dont have the key but i ill get one tommorrow and hope i am allrite
at my local yard they take the **** off if you dont have the tools
ok fixed it all got the key put it on and it still has this knocking sound
It sounds like it is coming from my clutch area but im not sure wtf is wrong i no i need to get a pm6 because right this moment i am using a hf ecu but i dont think that would make the car run like it is
Could the pulley coming off fucked something up?
SL0-hatch
Mar 11, 2008 08:27 PM
boostin4drcivic
10
Mar 9, 2004 05:20 AM
