best turbo manifold for h22....
I would like to know peoples opinions on which manifold makes the most power, and the best quality for my turbo h22, Im may be putting together a custom set-up.
I have no AC or PS, I will want to run a 3in Dp. Thanks, any help please.
There really isnt a magic manifold. I think any of the ones from Fullrace, Tinker, RPI, Sfp....are all very high quality and you cant go wrong buying one. That is if money isnt a problem.
The H22 SST places the compressor housing below the alternator, and leaves plenty of room for a 3" downpipe w/the front motor mount. Also, the full radiator should be easy to save. There are pictures on my website somewheres of this...
You *might* have to shave a smidgin off, like the "pinch weld" area. But Ive got is setup to where the downpipe basically hugs the block, then goes under the pan. If I remember correctly, there is 3" on the dot with the Lude/Accord Xmembers. So youll have to clearance slightly for engine movement. Email me for the nitty-gritty details!
eksleeper97
Sep 2, 2013 09:02 AM
