can my b series swap have to long of axles? becaus my wheels wont roll.....
Old Jun 22, 2004 | 02:37 PM
hammerdgolfer's Avatar
Default can my b series swap have to long of axles? becaus my wheels wont roll.....
so i thought my tranny was fucked up since i couldnt get it into netraul and get it to roll on flat ground, so i started taking off the hub assemblies becaus i was going to pull the tranny and needed the axles out.....
well i pulled the pass side off first, then the drvier side,then i realized the axles turn now! i thought the driver side hub just froze but i could turn it when it was off the car,,
so is it possible i have to long of axles? i dont know what they are from but i belive they use the midshaft with a vagina
Old Jun 22, 2004 | 02:59 PM
rioninja's Avatar
Default Re: can my b series swap have to long of axles? becaus my wheels wont roll..... (hammerdgolfer)
did you remove the hub rings?
Old Jun 22, 2004 | 03:01 PM
krazie1's Avatar
BANNED
Default Re: can my b series swap have to long of axles? becaus my wheels wont roll..... (rioninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hammerdgolfer &raquo;</TD></TR><TR><TD CLASS="quote">so i thought my tranny was fucked up since i couldnt get it into netraul and get it to roll on flat ground, so i started taking off the hub assemblies becaus i was going to pull the tranny and needed the axles out.....
so is it possible i have to long of axles? i dont know what they are from but i belive they use the midshaft with a vagina</TD></TR></TABLE>
what axles and set up u got?????
I know some can be long
Old Jun 22, 2004 | 03:18 PM
what are the hub rings?
i dont know what the axles came off, i bought them a while ago,
they use the midshaft with a ***** if those came on a specific car
Modified by hammerdgolfer at 12:29 AM 6/23/2004
Old Jun 22, 2004 | 03:38 PM
4G4Dreamindx's Avatar
Default Re: (hammerdgolfer)
vagina?!?...*****?!? WTF? is a freakin joke!?
Old Jun 22, 2004 | 03:42 PM
crx_88_si's Avatar
Default Re: (4G4Dreamindx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4G4Dreamindx &raquo;</TD></TR><TR><TD CLASS="quote">vagina?!?...*****?!? WTF? is a freakin joke!?</TD></TR></TABLE>
male, female, bah I understood it.
whats transmission do you have? which I-shaft did u use?
Old Jun 22, 2004 | 04:05 PM
Default Re: (crx_88_si)
how did you want me to escribe them?
b16 y1, what do you mean what I-shaft?
Old Jun 22, 2004 | 04:11 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">did you remove the hub rings?</TD></TR></TABLE>
take those dust covers out!
Old Jun 22, 2004 | 06:00 PM
Default Re: can my b series swap have to long of axles? becaus my wheels wont roll..... (4drEF)
im gonna take the dust coverso ut and if that doesnt fix it im gonna have to cry
Old Jun 22, 2004 | 07:31 PM
pokemon's Avatar
hub rings = problem, fix it ;]
Old Jun 22, 2004 | 10:02 PM
before i go out and take them off does anyone want ot tell me how to get them off?i looked tonight but it was to dark, it was cloudy all day
Old Jun 23, 2004 | 10:33 PM
ok what the **** guys??
my axles, when i tighten my axle nut it holds part of the axle against part fo the hub that doesnt move.... so in turn it wont roll....
god dam supposedly im getting axles this weekend that are made for dx hubs, i took the dust shields off but i was wondering why they would make a dif?
Old Jun 23, 2004 | 11:06 PM
Rywire's Avatar
go to the link in the sig, click b16a step by step. Ryan
Old Jun 24, 2004 | 07:31 AM
4drEF's Avatar
Keyboard Humorist
Sounds like they might be ABS axles with the ABS ring around them.
I tried putting 92~95 D series axles on a 88~91 D series car. It didn't fit - ABS axle was too fat and locked into the actual knuckle.
Old Jun 24, 2004 | 08:22 AM
slowpokesi's Avatar
did you remove the dust covers yet,
you need to anwser our freaking questions if you want some help with this.
What Axles are you using,
What Intermediate Shaft are you using.
For info about the dust covers, goto my website and read the swap guide.
http://customcivics.com/~brandon
Old Jun 24, 2004 | 05:11 PM
ya i took out the dust covers, there were 3 screws holding them on(they didnt just pop out like your guys)
i dont know what the axles came from but they have a male midshaft,
im supposedly getting some axles this weekend that bolt right up to my d series hub,
it really sounds like i have the abs axles i guess, like 4dr ef said
Old Jun 24, 2004 | 06:33 PM
smokey2.0's Avatar
if your axles happen to have an ABS ring, remove it if they don't look for a rubber seal at the end of each axle right at the base of the splines. if you do not remove that rubber piece, your axles will bind! hopefully this helps you out!
1bar_ek
May 18, 2008 04:44 PM
hellogoodbye
Apr 5, 2004 04:11 PM
MugenGTR
Jul 24, 2002 08:43 AM
