help! gsr intake springs are shorter
Old Jun 22, 2004 | 01:43 PM
93hatchin's Avatar
Default help! gsr intake springs are shorter
iv noticed by side by side comparisons that my gsr intake springs are shorter than my itr intake springs .
The only conclusion i found is that the itrs havent been compressed yet. they are new. The gsr intake springs are used. help anyone?tia
Old Jun 22, 2004 | 01:52 PM
93hatchin's Avatar
i just installed cams too ctrs what is the valve adjust specs on them?
Old Jun 23, 2004 | 11:46 AM
93hatchin's Avatar
bump
Old Jun 23, 2004 | 01:45 PM
93hatchin's Avatar
Default Re: (93hatchin)
nobody knows why?
Old Jun 23, 2004 | 02:24 PM
black98gsr-t's Avatar
Default Re: help! gsr intake springs are shorter (93hatchin)
should be .006 on the intake and .007 on the exhaust. not 100% sure but this should work just fine.
Old Jun 23, 2004 | 05:45 PM
dfoxengr's Avatar
Default Re: help! gsr intake springs are shorter (black98gsr-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black98gsr-t &raquo;</TD></TR><TR><TD CLASS="quote">should be .006 on the intake and .007 on the exhaust. not 100% sure but this should work just fine. </TD></TR></TABLE>
thats valve lash
lol. probably because they are different spring rates
Old Jun 23, 2004 | 07:56 PM
gsrswapdcivic's Avatar
Do you have JDM gsr springs?. if you do they are a little shorter.
the valve adjustment is .006MM intake and .007 Exh. thats what i run and you can not hear any valve lash under the hood. (most people dont adjust right thats why their car clicks bad)
when i installed my Skunk2 springs they were very short compared to the gsr exh. springs. called skunk and they said that the springs were fin and you just put them in and install the rest of your valve train.
the spring being taller should not matter it is just the diff. in spring rates.
also when you adjust the valves it wont matter keeping the same adjustments cause you adjusting it to the hight or the spring. thats the only thing that matters. the springs will work out
Old Jun 24, 2004 | 12:44 AM
93hatchin's Avatar
oh ok thanks. i guess i got freaked out.the springs are usdm.and im using the intake side gsrs for the exhaust side then itrs for intake. the part number is the same for the itr exhaust so i doubt there will be a prob.thanks for the help i needed it. ive heard that gsr springs are way stiffer btw......
denraweb
Jun 5, 2011 12:57 PM
Jintegragsr97
Feb 21, 2008 08:44 PM
A2_8U
Jun 8, 2006 01:24 PM
B HATCH
13
Sep 6, 2004 12:25 PM
McFly
Feb 12, 2003 08:27 PM
